Help Rim width and tire sizing advice
Im planning on buying a set of Aodhan ds06 (ET22) but I’m not sure what with to get for my rears. I’ve seen many people run 11s in the rear and a squared setup of 9.5 all around, both look flush but I’m not sure if it’s because AWD is different or if it’s a coupe but I have a 2011 G37xs coupe if anyone could help me with proper fitment I’d appreciate it, id like to not have to run spacers. as well as what tire sizes should be done with the rims
thanks.
thanks.
a few things to consider;
1. Does the amount of negative camber matter?
2. Are you fine with tire stretching?
question about the wheels;
1. is the 11.0" offset +22 or the 9.5" offset +22?
assuming 11.0" +22, this will require a good bit of negative camber and some tire stretch.
Use this as your example
https://www.fitmentindustries.com/wh...wering-springs
abz10 (04-01-2022)
This is a DS08 19x11+15 with 285/35, front was 9.5 +15 with 255/35 (don’t have a pic) and the fit was great on coilovers. Car was from Toronto actually, you may have seen it around.
