G35 Rays Lugs
Old 12-28-2016, 05:56 PM
greco65
greco65's Avatar
G35 Rays Lugs
Gents,
I just installed my old G35 19" rays on my G37 sedan. They look Great to say the least. The shop where I installed them told me that I may need different lugs. I read here in the treads that when you have OEM wheels you suppose to use the OEM lugs and when you have aftermarket wheels you can use aftermarket lugs. I was wondering what about my setup? Do I need to get OEM G35 lugs?
Old 12-28-2016, 09:47 PM
HoldmyMouse
HoldmyMouse's Avatar
Originally Posted by greco65
Gents,
I think the tech was referring to the style. Acorn vs shank w/ washer
Old 12-28-2016, 09:58 PM
Epiphany
Epiphany's Avatar
[/URL]
Definitely talking about these. It'll depend whether the Rays use a washer seat or tapered seat. You should be able to take a picture of where the lug would sit on the wheel and post it here for an answer. Or see this: will be the first or second picture.
By the way, happen to have a pic of the rays on the car? I was looking at a used set before and was curious how they'd look on the G37.
Old 12-28-2016, 11:31 PM
antirice
antirice's Avatar
I have G35 rays on my G sedan as well. Yes they use different nutz, the ones without the washers like in the pic above. So make sure you get the correct ones.
Old 12-29-2016, 12:31 PM
greco65
greco65's Avatar
Here are the wheels. They are powercoated.
The following 3 users liked this post by greco65:
Epiphany (12-30-2016), gill1606 (12-29-2016), VIVID (12-31-2016)
Old 12-29-2016, 07:40 PM
greco65
greco65's Avatar
The part number for the short lug nut is 40224-ZN50A and it is a great idea to get it from a Nissan dealer instead of Infiniti. I went to Infiniti to make sure I get the right part and then I run to Nissan to purchase it. Infiniti want to charge me $5.44 each and Nissan Charge me "only" $3.40 each.
Old 12-29-2016, 07:42 PM
greco65
greco65's Avatar
Next thing will be shocks/springs and hopefully I am done. I have not decided yet which way to go.
Old 12-29-2016, 09:37 PM
Received 4,943 Likes on 4,176 Posts
Get the Tein Basis Z, can be had for under $500, Japan sourced product, exact height you want, WIN WIN all day long!
greco65 (12-29-2016)
Old 12-29-2016, 10:15 PM
greco65
greco65's Avatar
The Tein Basis Z are the coil over or just the springs?
Old 12-29-2016, 10:16 PM
HoldmyMouse
Zero noise coilovers
Old 12-29-2016, 10:29 PM
4doorfury
4doorfury's Avatar
Hey Greco can you post some side pics and a picture along the side of the car so I can see how these sit with the fender front and back? Been debating them just was curious on the stance. Thanks!
Old 12-30-2016, 11:22 AM
greco65
greco65's Avatar
Here is the photo. The front is flash but the rear is sticking out about 1mm.
Old 12-30-2016, 11:34 AM
Tachyon
Tachyon's Avatar
I would recommend getting the correct lugs as soon as possible. The acorn style lug nuts will basically bore out the lug holes and your wheels can break off....
I have the same wheels and had to get shank style lug nuts. I bought them from another member here. Going to the dealer is very overpriced.....
https://www.myg37.com/forums/brakes-...ck-wheels.html
The following 2 users liked this post by Tachyon:
blnewt (12-30-2016), greco65 (12-30-2016)
Old 12-30-2016, 12:37 PM
Received 4,708 Likes on 3,516 Posts
Good move cross shopping to Nissan. $34 is totally reasonable for a set of OEM lug nuts, IMO.
You're not driving around withthe wrong design lug nuts right now, are you?
Old 12-30-2016, 03:45 PM
greco65
greco65's Avatar
OK....I had the shank with the washer and I went and bought the acorn. I have not driven them yet but I guess I installing again the original (shank with the washer) and returning back the acorn.
