View Poll Results: Staggered set-up g37s.. how many miles do tires last?
10,000~20,000
7.14%
20,000~30,000
64.29%
30,000~40,000
21.43%
45,000~50,000
7.14%
50,000~55,000
0%
Voters: 14. You may not vote on this poll
Old 08-03-2016, 03:51 PM
Received 4,711 Likes on 3,519 Posts
Pretty hard to get PSS to squeal, even when pushing hard.
Turn off the TC and you can do all kinds of things with the car, even with Michelin PSS.
Granted, there's probably better tires out there, but PSS are the best I've ever owned. Great tire.
Old 08-03-2016, 06:44 PM
4DRZ
4DRZ's Avatar
Maybe I missed it, but you are planning to run the same size tire all around? Why would you not be able to rotate your wheels front to back to save on tire wear? AWD will also help you extend the life of your tires over RWD. Ultimately, it will come down to where and how aggressively you drive.
Old 08-03-2016, 07:22 PM
G37X GraSdadow
G37X GraSdadow's Avatar
Because I have staggered wheel set. I was told that 245/40's all around for X is the best set up for 19"s staggered or not.
Anyways, I am swapping my 9.0 rears for 8.5 fronts tomorrow so I will have 8.5 square set!
Old 08-03-2016, 07:40 PM
Problem solved.
Old 08-03-2016, 07:49 PM
Lego_Maniac
Lego_Maniac's Avatar
Agreed. The combination of wet/dry performance, price, and wear is great. I'm on my second set, and I'll probably need at least new rears around the first of the year.
Old 08-04-2016, 02:16 PM
4DRZ
4DRZ's Avatar
Well, there you go. You should still be able to swap front to back with only .5" difference in rim width with the same size tire on both ends if the trade doesn't go through.
Old 08-04-2016, 03:21 PM
G37X GraSdadow
Just received front set from Phil (Gregor12). Thanks man!
Also ordered 4 xc ontinental DWS 06 for the set up.
Can't wait to put them on.
7Head
04-10-2016 08:22 PM
WalterC
03-30-2016 06:39 PM
Quick Reply: Staggered set-up g37s.. how many miles do tires last?
