Please help with wheel size
Hey guys sorry this will be my first after market wheel purchase and I just want to confirm with you guys. I am in the process on ordering niche m130. I want to stay close to oem specs as possible. I have a rwd coupe btw.
front: 19" x 8.5", +35 Offset, 5x114.3 Bolt Pattern, 72.6mm Hub.
rear: 19" x 9.5", +35 Offset, 5x114.3 Bolt Pattern, 72.6mm Hub
Will my car be ok with these specs? thanks a lot guys
Yeah, if you have the RWD S coupe you will have to confirm brake clearance w/ the vendor.
Otherwise those wheels will fit fine, especially since you want to stay w/a more conservative OEM-type fit.
You will need hub adapter rings, most wheel vendors will carry them or you can order aluminum ones on ebay, they need to be 72.6mm outside, 66.1mm inside.
this will decrease and hopefully eliminate any high speed vibration issues.
