Changed up my stock wheels a bit....
Center cap: http://www.ebay.com/itm/141955626867?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITBlack lugs: ZSpeed Performance Nissan Infinti OEM & Performance Parts
Originally Posted by Brian6t5
Are these actual center caps or discs that go over your oem caps with double sided tape?
This design is different as you can see they actually stick out while the OEM ones are flush which I really like because the black is more noticeable that way I think...
They came with 4 center caps and 4 high quality plastic decals that you paste on the provided center caps. They are in no way cheaper then the OEM ones which are honestly just cheap crappy plastic any how...
Black lug question
Where or how did you get your black lug nuts? Since I powder coated my oem wheels I've been looking for black lug nuts. I think I'll go for center caps too. Thanks for posting.
Here is the link again...they are not cheap but they are high quality and I could not find anyone that made the proper size for our cars. These are the same as OEM, visual and physical size and washers etc.
http://www.zspeedperformance.com/370...-blacklugs.htm
Brian6t5 (06-01-2016)
G37sGraphite (06-01-2016)
