Offset Question
Offset Question
Hi,
I have a 08 G37 Coupe RWD Base and was wondering if these wheels will fit my car with a flush look. They are 19x9.5 all around with both +22mm offset for front and rear. Is my rear going to be poking out to much? Right now it's on stock suspension but I plan on getting coilovers in the future to drop it as well.
Thanks!
Thanks!
08G37S_ (02-21-2020)
What about 18x9.5 +22 front and 18x10.5 +22 rear? Is the rear to aggressive? I also have 225/50/18 tires all around.
Thanks for the info. What about tire size for 18x9.5 +22 all around? Would 225/50/18 work? Or is it to big of a stretch. What size tires would you recommend? Or should I go with 18x9.5 +22 front and 18x9.5 +30 rear?
Thanks and will do.
So I have planned to go with 19x9.5 all around with +30 front and +22 rear. Would this work out? Also should I go 255/40/19 all around or should I get a meatier tire in the rear?
Thanks for the help.
The Steering Wheel Guy
A 225/50 on a 10.5" wheel? I would definitely reconsider. I'd be more concerned with a 9.5" +22 on the front than the rear. I have a 19x9.5" +20 and 255/40R19 on my rear and it fits fine.
A 225/50 stretched on a 10.5" wheel on a RWD car will be like ice skating.
I am looking at some Varrstoen ES6, pretty much a replica of the Work Meisters.
Would a 19x9.5 +30 be better for the front? Would it clear when lowered?
