Offset Question
Old 05-24-2016, 02:41 PM
jameswouldgo
jameswouldgo's Avatar
I found this:
https://www.myg37.com/forums/brakes-...ml#post3815735
Someone running 18x9.5 +30 all around with 265/40/18
Old 05-24-2016, 03:24 PM
VenomGT9
VenomGT9's Avatar
Sooo...why not just get a set of the Meisters?
Old 05-24-2016, 03:28 PM
jameswouldgo
Lol I wish.
Old 05-24-2016, 03:34 PM
saywat?
saywat?'s Avatar
any pics of the wheels in 19" on a g37? i think itll look small bc of the design. might have to go 20s? unless u gonna go super low
Old 05-24-2016, 03:37 PM
VenomGT9
VenomGT9's Avatar
You'd be better off going with a different set all together...try enkei or ssr.
the SP1s are a pretty small/fugly wheel
Old 05-24-2016, 03:58 PM
jameswouldgo
I only could fine these two with actual Work Meister:
JPSBLACKG37 Infiniti G37 - MPPSOCIETY
FS: Work Meister S1 19x11 +5, 19x11 +17
I don't plan on going super low...
I was actually looking at the Varrstoen Es2 too. Their TE37 replicas.
Old 05-24-2016, 04:02 PM
jameswouldgo
Would I be better with 19x9.5 +30 front and rear? Or 19x9.5 +30 front and +22 rear?
Old 05-24-2016, 04:20 PM
VenomGT9
VenomGT9's Avatar
Keep the +22 rear, trim the bracket if need be
Look into a set of SSR GTF01, a little better looking from a much better company
Old 05-24-2016, 04:25 PM
jameswouldgo
So fronts +30 255/40/19 and rears +22 275/40/19? I'll check it out, thanks.
Or 255/35/19 all around like Ryne?
Old 05-24-2016, 04:29 PM
saywat?
saywat?'s Avatar
most people go 245/40/19 f 275/35/19 rear thats wat id suggest
jameswouldgo (06-02-2016)
Old 05-24-2016, 04:54 PM
Ryne
The Steering Wheel Guy
Ryne's Avatar
Originally Posted by jameswouldgo
So a 19x10.5 with a 275 would require some camber? Would it be poking and rubbing?
You would need to trim the fender liner and bumper bracket. Camber needed would be about -2 to -2.5
Old 05-24-2016, 04:57 PM
Ryne
Ryne's Avatar
Front: 19x9.5 +25
Rear: 19x9.5 +20
Tires: 255/35R19
Old 05-24-2016, 04:59 PM
VenomGT9
VenomGT9's Avatar
275/35 for the rear at most...keeping the staggered set up.
Old 05-24-2016, 08:29 PM
  #29
jameswouldgo
I decided to go for either the 19x9.5 +30 front and 19x9.5 +22 rear with 255/35/19 all around (similar to Ryne setup). Or 19x9.5 +30 all around with 265/40/19 all around (similar to Lt8Che setup). Is this a wise choice? Any suggestions? Should I do a staggered tire setup instead (notice their both AWD)? Thanks for the help guys!
Old 05-24-2016, 10:58 PM
  #30
Ryne
Ryne's Avatar
You are correct, I am AWD, which played a role in my decision. If I was RWD, I would want AT LEAST 275 out back, probably 285.
Quick Reply: Offset Question
