Rim/Wheel Dimensions
I was thinking about getting some rims but don't want to get a separate set of tires. Currently running 225 front and 245 rear.
I know the stock sport rims run 19x8.5 and 19x9
If the rims I'm looking at are offered in 19x8.5 and 19x9.5
Which would fit the 245 tire best?
Thanks.
Thanks.
If you buy an aftermarket set of wheels the same size as the current ones you have then yes you can just swap tires and adding .5 in the rear is fine but no more than that.
Thanks.
Thanks.
The 245 printed on the tire stands for 245mm wide, which when it's converted to inches is just about 9.6 inches. They will be your rears.
I know the rear stock are 19x9.
but the aftermarket wheels I'm looking at only come in 19x8.5 and 19x9.5
Can I use the same rear tires that are currently on my stock rear rims with either the 19x8.5 or the 19x9.5?
Yep, like I stated, they will be a great fit for the rears. The 225 will be just fine on the front too but maybe a bit meaty for the cars taste, not sure..
https://www.toyotires.com/tire/patte...e-summer-tires
stealthee (05-01-2016)
johnadlertech
07-02-2016 01:55 PM
