Tire Fitment
blnewt (03-18-2016)
If Vossen told you that then they know what they're talking about. I have a set of Vossen's on my awd coupe now 20x9 +32 20x10.5 +45. You also may want to choose a +27 rear offset for a more aggressive look without the need for wheel spacers which was a mistake I made. You could've gotten an answer for this question with a 20 second search on this forum.
ZOSTER33 (03-19-2016)
kennyz424 (03-19-2016)
I am running 19x11 +15 on my X coupe with only 1.5 degrees of negative camber, lowered on coilovers without any issues. Tires have minimal stretch (275/35/19) Used to run a 20x10 +20 and tucked pretty good had a solid 3/4 inch before touching the fender so you'll be totally fine.
Upscale Speed
03-14-2016 11:11 PM
