Spacers with Stock Suspension
Old 03-03-2016, 12:48 PM
Goonz
Goonz's Avatar
Exclamation Spacers with Stock Suspension
I'll start off by saying that yes, I did search and all the results yielded cars that were already dropped or sedans on stock suspension. I have stock 19s with stock suspension looking to add a bit of aggressive stance to the car. Seems 20/25mm is the best setup but it seems a bit excessive and something that would best suit cars that are dropped. Any recommendations? I was leaning around 15mm all around even on staggered wheels? Pics would be appreciated as well.
Old 03-03-2016, 01:07 PM
VenomGT9
VenomGT9's Avatar
Best bet would be to just measure from where it is now vs where you want.
On my G35 I had 25mm all around and still had some room to play. I feel 15-20mm would be sufficient for you.
Old 03-03-2016, 01:25 PM
reNeglect
reNeglect's Avatar
Depends on your tire size. 245/40 & 275/35 On the OEM 19' Enkei wheels, 20MM in the front has a little to much poke and the 15MM rear is perfect.
Old 03-03-2016, 01:34 PM
Xenolith666
Xenolith666's Avatar
Additional question.. not to hijack or anything.. but I have a square set up on stock sport 19x9's.. 15mm work all the way around? also not lowered
Old 03-03-2016, 02:43 PM
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
15mm will "work" all the way around. In my opinion its about taste from 15mm down.
As one poster stated I think 15mm rear is perfect on stock wheels and tires. I would go with no more than 10mm front.
if you go spacers I would really recommend a drop. i think that spacers on the stock setup accentuates the front wheel gap a lot more.
Old 03-03-2016, 04:05 PM
Goonz
Goonz's Avatar
I agree, the only thing is that I have a year left on the lease and that period of dropping the car is gone (regret that I didn't). However I feel the 10/15mm setup will be ideal. I guess I'll give it a shot, any more pics of users running spacers on their stock setup?
Old 03-04-2016, 12:47 AM
Goonz
Goonz's Avatar
So I went ahead and purchased 15mm spacers all around (B2 auto designs doesn't make a 10mm spacer for their version 2 series). I'm hoping this should significantly improve the look of the car, will post pics once it gets nicer out and I install the summer wheels.
Old 03-04-2016, 12:54 PM
zib331
zib331's Avatar
Project Kiks has a 10mm hubcentric spacer with built in studs. I'm going with 10mm all around on my car with 245/275 tires on stock suspension.
I really hope 10mm all around gives me the look i'm looking for. Wish someone could post a picture of their car with 245/275 tires and stock suspension with 10mm spacers all around.
Old 03-04-2016, 01:09 PM
reNeglect
reNeglect's Avatar
Did you look at mines? With 20MM front 15MM Rear, its quite aggressive i must say. But 10MM should be aggressive as well.. make sure to anti seize the hub =)
Old 03-04-2016, 01:21 PM
Mr_Mer
Mr_Mer's Avatar
I see that you got spacers already, but I do have 20/25mm dropped. It looks like this:
I think 20mm F is perfect, maybe 30mm R would do it with the installed wheels. This is a squared setup.
Old 03-04-2016, 05:07 PM
Goonz
Goonz's Avatar
Very nice but again your car is dropped so it looks really good. Mine isn't so I have keep that in mind. Car looks nice!
Old 03-04-2016, 05:59 PM
Mr_Mer
Mr_Mer's Avatar
It sure looks better dropped. And thanks!
Here it is on spacers, no drop
Old 03-05-2016, 11:43 PM
Ape Factory
Ape Factory's Avatar
20f/25r here, really felt it was too aggressive visually initially but now I like it. I will say from a performance standpoint, I think 20mm up front is pushing it. I did notice a difference in initial steering sensitivity at higher speeds but I've adjusted.
Personally, from a safety standpoint, I'd probably go with spacers that utilize longer studs as opposed to two sets of studs. You'll have to pull off your wheels to make sure the inner nuts are torqued to spec and they could, theoretically, become loose enough to cause catastrophic failure. It's unlikely but definitely crosses my mind as I hurl down the highway at 70+mph. Very easy to just whip out the torque wrench and check a one-stud spacer setup. Yeah, initially it's a PITA to install but long term piece of mind is probably worth it.
The following 2 users liked this post by Ape Factory:
Goonz (03-06-2016), reNeglect (03-06-2016)
Old 03-06-2016, 12:21 AM
reNeglect
reNeglect's Avatar
Nice IPL! Stock tire sizes?
Old 03-06-2016, 01:03 AM
Ape Factory
Yes, all stock for now. Debating going up in width once it's time to replace the stock RE050A's.
Quick Reply: Spacers with Stock Suspension
