Help Miro wheels
Old 03-02-2016, 09:55 AM
lobuzz311
lobuzz311's Avatar
Miro wheels
Yeah. Those are sweet, but multiple bolt patterns screams cheapo "tuner" wheel.
Edit. On 2nd look, that might just be an accent cutout, not a 2nd set of lug holes. (they don't look round)
Old 03-02-2016, 10:25 AM
VenomGT9
VenomGT9's Avatar
I thought so at first too but then again it is Konig...so I wouldn't put it past them
Old 03-02-2016, 11:16 AM
lobuzz311
lobuzz311's Avatar
If you look at their current lineup, they're all single lug pattern. I can't imagine one of them (the newest, it seems) would be multi-line, since that's not really done any more. It's too bad they don't have them available in more colors, as a set of 21 lb 19s @ 1000 bucks would be sweet, but I'm not gonna pit matte graphite wheels on a grey car.
Old 03-03-2016, 02:55 PM
4DRZ
4DRZ's Avatar
Unfortunately the jump in price from 18s to 19s is pretty big w/ the Weds & Gramlites, The Work Kiwami are a bit less at around $470 per but still busting your budget
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Work CR Kiwami
Might give a look to Konigs flow formed wheels, they have some nice looking sets that should do well w/ your price point
Flow Formed Wheels - Konig Wheels
These are a nice look IMO and should be about the same weight as the Integrams which are 22 lbs in a 19x9.5 wheel.
Phew! I thought I was losing my mind looking at Gramlights and Work in 19" when I saw the pricing. I had a set of Wedsport wheels picked out in 18" and then I discovered I cannot get the really sticky tires in the right size for 18". Konig makes decent wheels. I actually had a set of gold Milligrams on my Evo and they were very light and strong. I wish they made them in 19" and silver.
The Konig Interform wheels are nice and light and look decent. The Hypergrams would look nice in silver, but they do not come in 19's either. The Rennforms are ok, but they don't post the weight. Were there other Konigs that you were looking at? Thanks for digging a little deeper for me. I appreciate the effort.
I still like the look of the Miros the best, just not the centercaps. I think the TSW Interlagos are a close second with their funky offsets. Still open to suggestions, but I will need to order them relatively soon for an upcoming track day.
Thanks again for all the suggestions guys!
Old 03-04-2016, 02:38 PM
4DRZ
4DRZ's Avatar
Well after a lot of research and talking to guys who had the Miros, I finally pulled the trigger and ordered a set of 19's w/ some sticky Bridgestone RE-71R tires from the local discount tire. Excited for it to warm up so I can finally accelerate and corner again. Seeing the traction control light every time I graze the gas pedal is getting old
Old 03-04-2016, 07:44 PM
Received 4,942 Likes on 4,175 Posts
Nice! Look forward to install pics. Did you go 9.5 all around?
Old 03-04-2016, 09:01 PM
4DRZ
4DRZ's Avatar
I went w/ 19x8.5 up front w/ 245/40 and 19x9.5 in the back w/ 275/35. They made me an offer I "couldn't refuse." Here they are installed. Somehow they make my G37 look faster
Old 03-05-2016, 01:14 PM
guy from norcal
guy from norcal's Avatar
Huh....I thought your G was white ? Those wheels should look good. Can't wait for pics.
Old 03-05-2016, 03:20 PM
4DRZ
4DRZ's Avatar
No it faded a bit from all the sunlight here in snowy, cloudy WI
Old 03-10-2016, 01:31 PM
4DRZ
4DRZ's Avatar
So the Miro wheels came in, but they clear the front calipers with about 1mm or less. The guy at discount tire and I agreed that these would not be a good idea to run on the track if anything flexes or moves at all. So onto plan B- TSW Interlagos 19x9 +32 up front and 19x9.5 +41 in the rear. Hopefully, with a little more clearance and a stronger rim it will be a good fit.
Old 03-10-2016, 01:37 PM
the93owner
the93owner's Avatar
You could just add a small spacer to give it more clearance?
Old 03-10-2016, 07:16 PM
Yeah, why not run 3mm spacers, or have you already got your mind on those wheels?
Old 03-11-2016, 10:30 AM
4DRZ
4DRZ's Avatar
Spacers on the track are a really bad idea. Plus the TSW's are a stronger wheel which will also be better on the track.
Jesus-G37Sedan
05-18-2016 01:13 AM
Redfire32
02-21-2016 04:59 PM
InfinitiG37Ownr
01-29-2016 11:30 PM
SurreyG
01-29-2016 06:08 PM
Detailed Image
Lighting/Cleaning Products
01-29-2016 08:35 AM
Quick Reply: Help Miro wheels
