TPMS And Aftermarket Rims
I am in due need of new tires and have decided that I will just purchase a wheel/ tire package in the next month or so. Not trying to go overboard, just something nice on stock suspension such as the following picture. That being said, can the stock TPMS (tire pressure monitoring sensors) be installed on the aftermarket wheels, or will I need to purchase new sensors (TPMS Kit)
If the currents tires have any life in them you could just buy a new set for the new tires and keep the old ones around as winter wheels and keep your new rims out of the salt.
steven92 (02-08-2016)
hmm ok so ill order the TPMS sensors from tire rack as well. Yes, my OEM tires have about 50% tread left but one has a small leak and some have sidewall cracking. I will leave them on the OEM rims and use them as a winter set.
You will need to have the new TPMS sensors programmed to your car, they aren't just plug-and-play I believe.
He is 100% correct, the car has to be put into 'learn mode' and the sensors have to be initialized. I believe there is a DIY method involving differing tire pressures etc. I have access to the monitor and TPMS tool, so I did it that way. The whole process takes less than 15 minutes so it shouldn't cost much.Check the DIY section for the alternative method though, you may be able to get that to work.
I had to take the car to the dealer for the annual safety inspection and a small warranty repair. I knew they'd be a bit pricey but i figured I'd go ahead and have them take care of the snow setup.
They charged $30-something each to install the TPMS sensors and do the mount balance. Not cheap but not crazy and about what I expected for the dealer. The kicker was they charged $115 to program the sensors. Just the programming.... It was $272 to install the TPMS on the OEM wheels, mount and balance the tires and program the TPMS, all in. The state inspection was *free*.
In retrospect, I should have just bought the Quickset for $150 and did the programming myself. I'm sure a Nissan dealer can do it perhaps a bit more reasonably and some tire shops should have an appropriate tool as well. ...or buy the Quickset, as I'll do, now.
Pawn in Game of Life
I just recently went through this little exercise. I bought my new wheels, tires and TPMS sensors all separate. I took them to a local tire shop and had them clone my new TPMS sensors to my OEM codes, install in the wheels, mount & balance and swap out my OEMs all for $100.00. Now that the TPMS sensors are cloned I can change between OEM and aftermarket set ups without worrying about the warning light.
I did not realize that the sensors could be cloned. I guess it's not so much cloning as it is changing/spoofing the ID on the new sensors to match the others. That's brilliant, Al. I'm going to definitely look at doing that in the spring. Might have to call a few local shops.
Al Czervik (02-09-2016)
Hard to say... you'd have to get a quote. Keep in mind you would only need to have it done once though versus farking around with the codes everytime you swap wheel sets.
JUMBO PALACE (02-11-2016)
These are the wheels I am 90% leaning to on purchasing. It comes with the TPMS sensors pre-programmed. What do you think of this fitment? I am unsure whether to get 19" or 20" I do not want to lower the car due to the roads in NY area are garage and I do not want to bend my rims.
