G37s sedan wheel sizing
How big can you go on stock suspension?
Mines only got 18" 225 winters, Big Sport Brakes,
I gotta buy new rims for the summer.
I need 255's in the front and 275ish in the rear in 19 or 20"
What rim size should I be looking at and offset
Please help a fellow G out
Let me know if i can help you with your wheels/rim purchase
On stock suspension I'd go w/ 18s or 19s, if you want a lot of tire I'd run a offsets just a bit more positive than those mentioned above. A 9" +35 and a 10.5 +45 you could run 245s in front and 285s in back, if you plan to lower it down the road you could go a bit more aggressive.
DP
Here's a visual that will help, and use this calculator when trying new setups
The following 2 users liked this post by blnewt:
Mattyem (07-11-2016),
ModInJapan (02-02-2016)
RAVSPEC
Brakes/Suspension
04-21-2017 02:05 AM
