Stock wheels with spacers, no drop
Old 01-22-2016, 11:18 AM
4DOORFUN
4DOORFUN's Avatar
I'm considering some wheels spacers to use with my stock sedan sport wheels. I'm thinking this will make the car look slightly more aggressive and give the illusion of less fender gap.
Does anyone have a photo of a NON-AWD sedan with wheels spacers and OEM RWD ride height?
Thanks in advance.
Old 01-22-2016, 12:19 PM
G37sPhoton
G37sPhoton's Avatar
Interesting, i have a '11 sport sedan as a DD and have tossed the idea of lowering the car/bigger rims(19's) etc but just read too many members being unhappy with ride quality after drop and going back to stock. so as much as I want the look of a lowered car, just never proceeded with those mods. However, i have contemplated your above idea. on my previous 09 journey i had changed out the tires to conti's DWS and they seemed fatter and filled out the wheel gap nicely but not sure on the sport(maybe the DWs 06?) any way subbed for info...good luck.
Old 01-22-2016, 02:04 PM
JohnnyD
JohnnyD's Avatar
Hmm, I'm interested in seeing this as well.
Old 01-22-2016, 03:02 PM
35Sport
35Sport's Avatar
Here's one on eibachs
https://www.myg37.com/forums/g37-sed...g37-sedan.html
Old 01-22-2016, 03:27 PM
G37sPhoton
G37sPhoton's Avatar
that is a good flush look and height, but presuming that the drop just completes that aggressive look etc..without the drop, maybe it would not be so aggressive..or sleek need...must... have pics....
Old 01-22-2016, 03:30 PM
Daddy Fat Sacs
Daddy Fat Sacs's Avatar
sorry op but I see no point in spacers if your cars not lowered in some way
Old 01-22-2016, 03:46 PM
kimmspeed
kimmspeed's Avatar
I respectfully disagree. I'm going to do spacers on the vert without a drop to hold me over until I can do the 'right' wheels and offset. I agree that both axis benefit from adjustment. But, no reason to forgo the spacers because you're not adjusting height.
Old 01-22-2016, 04:01 PM
Daddy Fat Sacs
the wheels are not tucked at factory height so what are you trying to accomplish? as op states an "illusion" of less wheel gap...and its just that...an ILLUSION. but by all means...to each their own
G37sPhoton
G37sPhoton's Avatar
I think a pic=1k words for this topic. though even if it improved it marginally(i would be very happy) I'm certain that the 'w/o a drop its pointless' chant etc would still be the ruling opinion. fwiw i agree that drop+spacers offers the best look , but may just not be a feasible mod for some with DD's, especially in my case...my wife and i switch cars sometimes based on work issues so trying to keep the car as close to stock with some of its characteristics... so IN FOR PICS
Old 01-22-2016, 04:38 PM
kimmspeed
kimmspeed's Avatar
Various G's with stock ride height with spacers...
First might be offset. But, the outcome would be similar. The side by side is obviously a G35. Gives the right impression though.
Attached Thumbnails Stock wheels with spacers, no drop-side-pic-1.jpg   Stock wheels with spacers, no drop-2844898467_d07d6cfcd0_o.jpg   Stock wheels with spacers, no drop-photo-1.jpg   Stock wheels with spacers, no drop-car-008.jpg   Stock wheels with spacers, no drop-spacer.jpg
The following 2 users liked this post by kimmspeed:
Blksonic (01-23-2016), G37sPhoton (01-22-2016)
Old 01-22-2016, 05:09 PM
G37sPhoton
G37sPhoton's Avatar
^^^^ yep just what i figured, i still cant decide,...
nevertheless, the look with spacers is slightly better than stock and slightly is an improvement so thanks for the pics Kimmspeed it helps out alot.
Old 01-22-2016, 05:16 PM
4DOORFUN
4DOORFUN's Avatar
Kimspeed - thanks for posting those pics. Some look better than others as I suspect some of them are AWD with the higher factory ride height. As you know, the RWD G rides lower from the factory. Some really look better than I expected.
Old 01-22-2016, 05:26 PM
G37sPhoton
G37sPhoton's Avatar
^^^exactly and do some tire comparison as some will have a higher sidewall, that will also minimize the gap effect on your car. at least that's my plan...or until a pic is posted of a sedan with similar set up and it looks gangly and then no-go....thats my fear...keeps me awake at night...
Old 01-23-2016, 08:18 AM
Received 4,727 Likes on 3,532 Posts
Daddy is right. If you pull the wheels out flush with the fenders while still at OEM ride height, all you end up doing is accentuating the gap, which at normal fitment is lessened (perceptually) by the deep offset. Because of the improved fitment, the car will look better to you from the front and the rear and various corner shots, but the profile will just look wrong. And when you approach the car, you typically approach it from the profile, you don't slide into it from the corner of the car. After a while, this wrongness is going to drive you nuts.
OP, go right ahead and play with your car, that's what we do. But your premise is flawed, IMO.
Old 01-23-2016, 09:35 AM
4DOORFUN
4DOORFUN's Avatar
My other thought was to grab some coupe wheels. For some reason those look really good on the RWD sedans and the fender gap looks better than with the stock 18's (even though it measures the same).
Quick Reply: Stock wheels with spacers, no drop
