The owner of the rims sent me the info below, but I am new and don't quite understand it all completely so I thought I'd ask. Thank you all for your help!
18x8 +50 offset maxima wheels
The Infiniti 17" is a 17x7.5" +45 offset
Difference of 1.3mm on the front of the wheel and 11.4mm on the back
So if you have over 12 mm of clearance between the back of your rim and the suspension then all will be fine.
I have been watching craigslist for a couple of months since I got my G sedan and have not been able to find any G37 or G35 rims. These are satin black and I have a white sedan.
As long as your G isn't one w/ the Sport package (the bigger Akebono brakes) those will fit. You will probably want spacers though as the +50 offset is real conservative and your wheels/tires will be sunken into the fenders quite a bit.
Thank you!
Do you have any idea what size spacers I might need? and will I need them front and rear? Thank you
