Rohana offers the RC26 with these specs.. Any idea if these would fit? If so, what's max width tire? This is a pretty mild offset so I would image these could work
Yeah, those will work, I'd run a standard mount so a 285/30/20 will be OK.
I'm assuming you're going to be lowered.
Ya, I'm on BC Coils now.. What you think about a 295/30 tire?
I'm running 295/30s on a 10" +45 and only about 3mm inside the fender edge at zero gap and in-spec camber.
Your 11" +52 will be about 5.5mm further out, so the 295s will hit that edge, 285s should net a very similar fit to mine.
Here's a pic of my setup
[IMG][/IMG]
