Wheel Bearing ?
No. Generally rockauto will be the cheapest you'll find on almost any part. However, with wheel bearings you want to make sure you get a quality part. Buy the Timken one even if it's more expensive. It isn't absolutely necessary, but you might consider replacing both bearings on the same axle while you're doing the work.
Gotcha. Thanks!
The following 2 users liked this post by juan goose:
Black Betty (04-28-2015),
enronforme (05-01-2015)
if by chance you have not seen this. https://www.myg37.com/forums/the-lou...kauto-com.html
Thanks Juan!
Quick question- where the hell do you put the coupon code???
https://www.myg37.com/forums/the-lou...ml#post3881609
Enter the code in the "How Did You Hear About Us?" space on the checkout page (above your payment information). Do not enter any other text in that space or the discount will not apply. Click the "Apply" button and your discount will be subtracted from your parts order total.
