19x10 niche targa squared fitment
Greetings,
Looking at purchasing a squared fitment of 19x10 all around on a 08 sport coupe.
Niche Targa wheels
http://www.wheelfire.com/scontent/Wh...&TireSKU=18321
Tires
245/40/19
Looking for mild drop on h&r sport springs or tein s tech.
Anything i should be worried about with this setup? Do i need a camber kit?
Thanks in advance
Niche Targa wheels
Tires
245/40/19
Thanks in advance
First, if you want a mild drop H&R or STechs aren't the springs you should consider, those are the deepest drop springs on the market. Look into Eibach, H Tech or Tanabe (and Swift if they have a coupe application now).
Even with the milder drops I'd at least get the rear camber & toe kit, you can get by w/ this bolt-only kit if you don't want the arms
http://www.ebay.com/itm/UC018-72265-SPC-Rear-Camber-Toe-Kit-x-2-Both-Sides-for-370Z-late-G35-G37-/261229394875?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AG37&hash=item3cd27c3bbb&vxp=mtr
As far as the wheels/tires, I'd run offsets in the +35 range and run a bit wider tire like 255/35/20s since 245s are only recommended up to a 9.5" rim.
Greetings,
Niche Targa wheels
Tires
245/40/19
Thanks in advance
Niche Targa wheels
Tires
245/40/19
Thanks in advance
Kojack
10-09-2015 05:53 PM
