19x11 Rear Wheel?
Old 11-21-2016 | 09:57 PM
Originally Posted by Rey Escobar
Im new here and Im in the market for a set of wheels 19x9.5 +15 and 19x11 +18 on the rear I have a g37x sedan lowered on tein s tech so Im wondering if i can fit the rear ones without any camber just stretch tires but idk help please
Nope, those wheels will be poking way outside the fenders on a Sedan, even on a coupe it's way aggressive. For those width wheels you'd need offsets in the +35 range in front and +45 in back along w/ a slightly stretched 275 on that 11". Also you have to be very careful w/ tire sizing on your AWD, the front & rear diameters need to be under 1% difference to keep your AWD system working well at higher speeds. Welcome to the site BTW.
Old 11-22-2016 | 09:04 AM
Rey Escobar's Avatar
Rey Escobar
Thanks ✌🏽️
Old 11-22-2016 | 11:33 PM
Marionan's Avatar
Marionan
I used to run square 19x11 +15's on 275/35/19 tires, and didn't have any rubbing problems (X Coupe). I'm lowered enough to close the fender gap, but not slammed. Also wasn't running extreme camber it was somewhere around 1.8-2.0. There was too much poke though, and looked a little weird. I would definitely recommend a +25 or higher offset.
Old 11-22-2016 | 11:51 PM
Those coupes have about 15mm more room at the fenders vs. the sedan, that's some tight fit there^^^
Old 11-24-2016 | 11:45 PM
Rey Escobar
Thanks and have 2 more questions guys
1) 19x10.5 offset 43 do you guys think that will fit ?
2) 19x9.5 offset 12 will fit ?
I don't want to do any camber thanks in advance
Old 11-25-2016 | 12:30 AM
Marionan's Avatar
Marionan
Hey Rey,
after switching from the 19x11 i went with a 19x9.5 +15 245/35/19 and its pretty much flush with the fender, no rubbing at all.
Old 11-25-2016 | 09:17 AM
Hay Ray, you should post these questions up in the wheel/tire folder, and be sure to mention you have a sedan Wheels & Tires - MyG37
allando
06-26-2014 02:30 PM
Basicklee
02-21-2014 09:29 PM
Doggy
21
02-02-2011 01:59 AM
Staples
07-17-2010 05:49 PM
ishotya
12-02-2008 10:35 AM
