One rim, 3 brands, which one and why?
Hi
I was going to buy a set of Velgen VMB5 wheels and found Niche and Avant Garde with the same rim. If you bought a set of any brand, which one and why?
I will like a semi aggressive look (19"), flush rim with flush tires will drop on Swift springs Thanks.
VELGEN VMB5 Matte Gunmetal // 19x9 & 19x10.5 // 20x9 & 20x10.5 - Velgen Wheels - Velgen Wheels
Avant Garde wheels
Model Name: M510
Wheel Size: 19x8.5 front and 19x9.5 rear
Wheel Fitment: Fits (2008-2013) Infiniti G37S Sedan
Center Bore: 73.1mm (Hub-Centering rings will be provided at no additional cost)
Center Caps: Avant Garde Center Caps Included
Finish: Matte Black
Bolt Pattern: 5x114.3
Offset: 35mm front and 40mm rear
Niche Targa
Model Name: Targa
Wheel Fitment: Fits (2008-2013) Infiniti G37 G37S Sedan
Center Bore: 72.6mm (Hub-Centering rings will be provided at no additional cost)
Center Caps: Niche Center Caps Included
Finish: Anthracite
Offset: 35mm front and 35mm rear
Velgen
Model Name: VMB5
Wheel Size: 19x9 front and 19x10.5 rear
Wheel Fitment: Fits (2008-2013) Infiniti G37 G37S Coupe
Center Caps: Velgen Center Caps Included
Finish: Matte Silver
Offset: 35mm front and 45mm rear
Avant Garde wheels
Model Name: M510
Finish: Matte Black
Niche Targa
Model Name: Targa
Finish: Anthracite
Velgen
Model Name: VMB5
I'm not sure the relationship, but I think similarly A.G. M310 and Eurotech U02 are essentially the same wheels as well. Maybe knockoffs or child company or another company created under different name and in a different marketing strategy.
I would stay away from black or dark-colored wheels. I think that having dark or black wheels sort of defeats the purpose of custom wheels because it's hard for most people to see and appreciate the design.
If you want the all-black look, get a set of steel rims and you're done like a cop car.
If you're going to get custom wheels, go with a silver or other bright and VISIBLE finish.
Honestly if they're black nobody will appreciate that you have $2000 rims or whatever on the car. Just my two cents - no offense meant.
Thanks again.
All three similar designs, but the Advant Guard is a classier design, IMO. The spokes are clean, without all the extra lines. It looks more upscale to me. The Targa is weird, with that segmented deep inner lip, and the sculpted lug nut sections. The Velgen looks better, and the Advant Guard better still.
What are the weights? I'm guessing pretty much the same for all three, not at all lightweight, but not an anchor either. Getting them in 19" helps keep the rim weight down.
Post up similar sized pics of all three.
cmackin (08-22-2014)
G37fan09 (08-22-2014)
Yes, I already had a set of Niche Mugello in 20" (staggered), I did like the look, didn't like the feeling. I just will like to try another brand. I have to blame MiPwnYew for making me going for the Velgen, but then Blnewt comes with those SSR and now I'm considering that as well.That is the problem with this forum when you make up your mind, another member comes with something better. LOL
check out MiPwnYew ride
https://www.myg37.com/forums/wheels-...-tires-57.html
The Advant Garde M510. Compared to the other two, it has the most clean and elegant design. IMO.
LOL, man why did you do that, I was already set for Avant Garde or Velgen (19") now I'm confused. Seriously, I like those SSR the only thing is the size, the price is ok with me. They comes in 19x8.5 (38) and 19x9.5 (40) for sedans, Velgens comes 19x9.0 (35) and 19x10.5 (45) and Avant Garde
19x8.5 (35) and 19x9.5 (40) (not sure if AG are available in 10.5). I'm looking for a semi aggressive look, rim flush to fender, similar to MiPwnYew's ride.
If I go AG or SSR I know I going with a square set up (9.5) with different tire size.
What would you recommend for a semi-aggressive look?
I can't find all the wheel specs options for the AG M510. I think I need to call a couple of vendors to find out.
