Tire fitting on my G37s
Old 08-13-2014 | 05:19 PM
abelavin's Avatar
abelavin
Guys I need some help trying to find out if a set of wheels would fit my 2008 AT G37s coupe as I'm trying to order the tires?
I got a set of rims that are:
Front 255/40R20
Rear 285/35R20
Thanks.
Old 08-13-2014 | 05:22 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Front 255/40R20
Rear 285/35R20
Thanks.
Those are tire specs, width in millimeters/sidewall thickness, and diameter.
Wheels will have the diameter in inches, the width in inches, and the offset.
Try again.
Old 08-13-2014 | 07:29 PM
For those tires you listed you'll need rims for the front 20x8.5 or 20x9" w/ an offset about +30 to +35
For those rear tires I'd try a 20x10 +35
You also need to make sure whatever wheels you choose that they'll clear the big front brake calipers.
Here's a template that you can send to your wheel vendor to check clearance
http://www.conceptzperformance.com/i...akeoutline.pdf
Mattlorentzoe
05-24-2021 08:49 PM
mitchlt
08-20-2015 03:44 PM
ddayeg37s
08-09-2015 07:10 PM
SS2006
08-09-2015 05:32 PM
Quick Reply: Tire fitting on my G37s
