Rear Bumper Bracket
Did you try searching the forum? Found this with the exact same thread title https://www.myg37.com/forums/g37-cou...r-bracket.html
I'm assuming you're trying to get more clearance for your wheels.
Many have just just bent the tab up depending on how much space you need while others on the more extreme just cut it off completely. Whatever you do you have to also include the tab bolted area as well and trim the fender liner.
I did search and I saw that thread already, but they didn't have any good pictures. I'm not sure if I want to remove the entire bracket or just the part outlined in red
This shows the bolt/screw section cut off.
click?format=go&jsonp=vglnk_jsonp_14051280063189.html&title=Rear%20Bumper%20Bracket%20-%20MyG37&txt
This shows the section you are asking about already cut out.
click?format=go&jsonp=vglnk_jsonp_14051280285341.html&title=Rear%20Bumper%20Bracket%20-%20MyG37&txt
Depends on how low you are and the offset of your wheels. Cut it as close to the bolt and see if there is any rubbing.
Topher9425
12-01-2015 03:00 PM
