Aggressive Wheel ?
Old 02-21-2014 | 04:26 AM
Basicklee's Avatar
Basicklee
Aggressive Wheel ?
Hey guys seeing if you could help me out here. I was wondering if a 20"x10.5 -10 offset front and a 20"x12 +5 offset rear would fit on my g with a rear and front fender pull? my fronts are already rolled but was seeing if I can get these to fit with some pull and negative camber. Thoughts?
Old 02-21-2014 | 03:18 PM
Need 4 Speed's Avatar
Need 4 Speed
My guess would be you are prob going to need camber kits and super stretched tires, IF you can even get that to work. I know with a 20x10.5 +15 you need to be slightly cambered (no camber kits required, just natural camber from COs), rolled fenders and a stretched tire. Ive never had anyone do a -10 offset before though. I dont even know if its possible to get that to work without a wide body kit.
How far are you planning on pulling the fenders? It pretty touchy when you pull fenders more than a few mm.. You can cause paint cracking.. then you would have to have the fenders re-painted.
This would be a unique set-up for sure. Is there a reason you want to go with the -10 offset? A +15 is very aggressive and yet still sits nicely.
Basicklee (02-21-2014)
Old 02-21-2014 | 03:33 PM
Diego@Vossen's Avatar
Diego@Vossen
Those specs will be super aggressive. I have already tested our new 20x12 on my rear with a higher offset and sits beautiful with a 275/30/20.
Previously I ran 20x10.5 +15 at -2.6 camber with a 255/30/20 dropped on KWV3's.
Currently I am running 20x12 +30 with a 275/30/20 and pokes 5mm more vs. my previous setup. There is plenty of backspace for the 12 to fit with no issues. At +5 with a 20x12 its going to need a lot more neg. camber/fender work and more stretch!!
Old 02-21-2014 | 05:04 PM
Basicklee's Avatar
Basicklee
im currently on vossen cv7's. Same exact set up as your cv7s diego. 20x10.5 +15 Your set up basically inspired me to go with vossens lol this guy is running this aggressive set up on a 04 g35 coupe (im buying a used set of wheels dpe sp16) he had -2 camber in front and -4 in the rear. Running 245/30 front tires and 285/30 rear tires. My current cv7 set up is nice but I want to go with a lot more aggressive set up now...I know im going to need a lot more camber but if it can be done which I think it can then I would like to try it. Ive never ran a super aggressive wheel set up like this before so im seeing if anyone could give me some input on it
Old 02-21-2014 | 08:12 PM
Basicklee's Avatar
Basicklee
Hmmm thanks for the input brah. Now that I see how a +30 fits with our cars I really doubt I can get a +5 in there without fender work. Ill jus wait and see for another set. How you liking the 12s in the rear tho? upload an *** shot when you get a chance!
Old 02-21-2014 | 09:29 PM
Need 4 Speed
x2!
Come on Diego, show us dat a$$!
I bet those 12s are SIICK!
helloandchau
10-06-2015 06:26 PM
xpcgamer
09-07-2015 08:10 PM
Sylo
09-03-2015 05:44 PM
