Still Vibrations after Hub centric installed
Old 02-18-2014 | 12:13 AM
Voleduy's Avatar
Voleduy
Originally Posted by STR
I think it should as long as they are snug.
One question what brand of tires did you buy?
Acelera .. not sure if it's right but they are not branded name tire.
Old 02-18-2014 | 12:18 AM
Voleduy's Avatar
Voleduy
I had the same problem with a deferent car. When I bought the hub centric rings they where not a tight fit which did not center the wheel
propertly. So I bought some aluminum that had a nice snug fit and that
removed the vibration.
Make sure the hub centric rings fit snug in the rims and in the hub of the car.
Just order a set of aluminum HUB rings. Hopefully it will fix the issue.
Old 02-18-2014 | 12:19 AM
Voleduy's Avatar
Voleduy
Originally Posted by b2autodesigns
Most of the time it is one tire causing the problem. Road Force would tell you which one. If you have the stock wheels. Put one stock wheel back on at a time and test drive. If you put say the front driver stock wheel on and the vibration goes away. Then that tire and wheel has an issue.
i will try this weekend.
Old 02-18-2014 | 12:54 AM
STR's Avatar
STR
If the hub centric ring don't stop the vibration I afraid that it's going to
Be the tires. If you can't return the tires back your next step would be to balance
Them with road force...
Keep us posted..
Old 02-18-2014 | 10:04 AM
Hollywood619's Avatar
Hollywood619
Have your wheels balanced with the spacers on. It's easy
Old 02-18-2014 | 12:26 PM
Voleduy's Avatar
Voleduy
I didn't use the spacers in this case. A new set of aluminum HUB spring will arrive this week. I will keep all posted on this issue.
Old 02-18-2014 | 12:39 PM
GTLAW's Avatar
GTLAW
I bet it's cheap made wheels. Incurve Concave. Also tires they have flat spots.
Old 02-24-2014 | 09:58 PM
Voleduy's Avatar
Voleduy
finally update from the exiting issue.
I ordered a set of aluminum of the HUB centric, and found out that 2 out of 4 wheels that didnt not fit the HUB tightly enough to center the wheel while driving. I went ahead and install the HUB to the other 2 and swap one side to the other now.
Now, with that tight fit from the aluminum HUBs centric and from the swap. The vibration has been noticeable reduced more than 50% compare to before and seem to be controllable. However I need to call the wheel dealer to request a replacement for the other 2 wheel in order to get away from the vibrations.
That's it guy. Wheel problem ....
Old 02-25-2014 | 11:51 AM
STR's Avatar
STR
Sorry to hear that its your wheels.
Hope you get you problem resolve.
Do you have any pix of your set up it would be nice to see your wheels on your
car.
thanks.
Old 02-25-2014 | 06:24 PM
rmfnla's Avatar
rmfnla
The joys of aftermarket parts...
Old 02-26-2014 | 04:03 PM
Voleduy's Avatar
Voleduy
Haha true.
Old 02-26-2014 | 11:15 PM
Voleduy's Avatar
Voleduy
car.
thanks.
As requested, here are some pics of my babe from the beginning and after some of the cosmetic surgery
Old 02-27-2014 | 12:05 AM
Phimphasone's Avatar
Phimphasone
Is the whole car vibrating or is it the steering wheel? You may want to check your alignment after installing 20". My car was doing a similar thing and I just recently had the wheels balanced and got an alignment and fixed. Everything is now riding smoothly.
Fresh looking ride btw, I dont see enough red G's on these forums!
Old 02-27-2014 | 12:20 AM
  #29
Voleduy's Avatar
Voleduy
actually the whole car vibrating and I just recently done the balancing. I will do the alignment this weekend after the springs were installed.
Old 02-27-2014 | 01:05 AM
  #30
STR's Avatar
STR
Very nice ride!
GFTW
11-11-2015 02:56 PM
cparise
08-19-2015 01:51 PM
xxg00w0
08-19-2015 02:48 AM
gcruzjr78
08-18-2015 10:15 AM
pledes23
08-11-2015 10:54 AM
Quick Reply: Still Vibrations after Hub centric installed
