The Official "Find Rochester Some Wheels" Thread.
Old 01-29-2014, 03:36 PM
  #76
GoFightNguyen
Because Racecar
GoFightNguyen's Avatar
Got two nearly identical quotes from Need4Speed Motorsports, and GetYourWheels.com. Since I started this with N4S, that's who I'm going with. Plus, they didn't hide their shipping costs, whereas GYW claimed free shipping, yet somehow spread that expense elsewhere... to the tires, I believe. So, N4S gets my business.
The only remaining issue is waiting on the funds, which should be here in the next couple weeks. And the only remaining question is: can I use my OEM lug nuts, or do I need a set? Anybody know that answer?
Even if you *can* use your OEM lugnuts, now's a good time to upgrade, and add a little something to the wheels. Maybe some shorties?
Old 01-29-2014, 03:53 PM
  #77
Received 4,711 Likes on 3,519 Posts
The better time would be after I'm done, and the wheels are on the car.
I'm really into titanium for some reason. It's like this magical metal. So I'm thinking something like this:
Old 01-29-2014, 04:17 PM
  #78
Received 4,943 Likes on 4,176 Posts
Well I guess it's time to crack open the "Find Rochester some lug nuts " thread.
Those in that pic above look nice IMO.
Old 01-29-2014, 04:21 PM
  #79
Those in that pic above look nice IMO, although I prefer the closed end version. The gorilla lock system is pretty decent, would look good in satin black w/ your wheels too, that's what I'm currently using FWIW.
Rochesters' future lugnuts Rochesters' future lugnuts
Old 01-29-2014, 04:27 PM
  #80
GoFightNguyen
Because Racecar
The better time would be after I'm done, and the wheels are on the car. I'm really into titanium for some reason. It's like this magical metal. So I'm thinking something like this:
I've got the muteki lug nuts in burning blue
Old 01-29-2014, 04:30 PM
  #81
Hmm. That certainly has possibilities. Thanks, Brad. Either way, plenty of time for this later... assuming the OEM lug nuts can be reused with the Vossens. Figure someone will answer that one soon enough.
What exactly is keeping the lock groves from getting all scratched to hell? Seems that would happen right away.
Old 01-29-2014, 04:34 PM
  #82
GoFightNguyen
Because Racecar
The socket might be coated in nylon on either the inside or outside. That's generally how you prevent damage to the socket/lugs.
Old 01-29-2014, 04:35 PM
  #83
Bota36
Bota36's Avatar
I don't think they'll work with the Vossens. The OEM lugs are somewhat flat and not domed on the bottom how they need to be.
Old 01-29-2014, 04:48 PM
  #84
Good call, Bota.
Need4Speed just told me "No" on the OEM lug nuts. So I'm buying a set from them on the cheap, and will address replacements at a later date, after the wheels go on the car.
Old 01-29-2014, 05:04 PM
  #85
warped ideas
A quarter past stripped
warped ideas's Avatar
The OEM lugs are much fatter as well. The lugs I had to buy for my Vossens were more elongated and they also have a rounded conical shape for the seat.
Old 01-29-2014, 05:47 PM
  #86
warped ideas
The Vossen lug holes are pretty deep. No point in buying some fancy show lugs because you wouldn't be able to see them anyhow. You only "see" my chrome lugs when they are removed from the rims.
Below is a link to a side view of my car. You really can't see the lugs unless your really looking for them.
https://www.myg37.com/forums/members...0216-19359.jpg
Old 01-30-2014, 12:39 PM
  #87
These gorilla nuts here look fine... flat capped, and anodized in a titanium finish.
Anodized Titanium Aluminum Racing Wheel Lug Nuts Spline Drive M12x1 5 Qty 20 | eBay
Old 01-30-2014, 02:09 PM
  #88
Agreed, like that finish
Old 01-30-2014, 03:32 PM
  #89
alfredo24pr
alfredo24pr's Avatar
if vossen wheels are really that deep, get some extended lug nuts. If you don't mind then I would get this shape instead.
http://www.ebay.com/itm/Anodized-Titanium-Aluminum-Racing-Wheel-Lug-Nuts-Closed-Acorn-M12x1-25-Qty-20-/121120187927?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c33536617&vxp=mtr
I have had both designs and that one you chose loses the color a lot faster from screwing and unscrewing than this design
Rochester (01-30-2014)
Old 01-30-2014, 04:27 PM
  #90
Never realized there were so many lug nut options. These VOLK Racing lug nuts are pretty interesting, too. Really, really interesting.
