AWD light flashes after 80 mph. staggered setup
Old 09-18-2013 | 03:21 PM
Weiboy718's Avatar
Weiboy718
Originally Posted by ANMVQ
The AWD system is attached to the tranny ( You know that tho) if the AWD locks up or shatters "may" cause tranny damage.
BTW NEVER trust the dealer, Didnt you read my BOOM story, LOL
What happened afterwards? The only thing I remember was your dealer told you to go pound sand.
Old 09-18-2013 | 05:33 PM
ANMVQ's Avatar
ANMVQ
WOW where you been man, Nothing sold the SC went back NA, Sold wheels, and all my CF ex the hood. Still driving it
Old 09-18-2013 | 06:16 PM
keraxis's Avatar
keraxis
Tranny blowing up
Honestly it probably wont blow your tranny up.. If it bind then it will destroy your front or rear spider gear and your car will become front or wheel wheel drive depending on how it goes. Lots of Evo, wrx and speed 6 guys have done this. The diffrence in tire size make the tranny think the wheel are always slipping. The tranny is probably over heating because the AWD is activating at 80mph for however long you are driving. (no tranny cooler) What this can do it burn your fluid which will make it less viscous and then start to shread components.
Old 09-18-2013 | 11:33 PM
Himalaya's Avatar
Himalaya
so would I be able to run these tires if i were to say stay under 80 all the time? the light only turns on after i go over 80 mph, not before, no matter how long i drive.
approx how long do i have from when the awd light turns on till the awd fries?
I'll probably be switching to 285 in the rear soon though to fix this problem
Old 09-19-2013 | 08:04 AM
ANMVQ's Avatar
ANMVQ
An why would be be increasing the rear size?? You need to go the other way. Should be looking closer to 265's for the rears, thats if my math is right, I ran 235 fronts and 255 rears with zero issues, An was touch 3 digets a lot, LOL
Old 09-19-2013 | 09:02 AM
Going from a 275 to a 285 gets the diameter difference below 1% when using a 245 front.
Old 09-19-2013 | 10:11 AM
ANMVQ's Avatar
ANMVQ
ok? I thought it was the other way to get the ORD to be below 1. But you probally now better than me.
Old 09-19-2013 | 11:17 AM
With your front tire size it could very well be better to go narrower on the rear, w/ the 245s the 285 is the ticket, funny how all these tire calculations work out. Good thing we have all these tire calculators as my head would explode w/out them
ANMVQ (10-01-2013)
Old 09-29-2013 | 04:43 PM
Jrwabw's Avatar
Jrwabw
I actually just experienced this also. I have a 2011 g37x coupe with the stance sc5 rims 245 front 275 rear. I was in a series of hard high speed pulls but after 2 or 3 min of slowing down and driving at about 65 it turned off. I will definitely be switching to 285s
Old 10-01-2013 | 12:48 PM
Himalaya's Avatar
Himalaya
For some reason, mine stays flashing until i pull over, turn the car off, and turn it back on
dAgent
12-01-2015 09:03 PM
mastapro
08-31-2015 02:45 PM
G37xS-Life
08-27-2015 10:34 AM
zzww1251
08-08-2015 06:19 PM
Quick Reply: AWD light flashes after 80 mph. staggered setup
