Fitment question?
Fitment question?
Hey guys, I'm looking at some strasse forged s8 wheels that are 19x9.5 +25 and 19x10.5 +22. Here's the thing, they are off a lexus so I would have to get adapters and the thinnest that they make is 15mm. Do you guys think these wheels will fit with the 15mm adapter/spacers all around without going negative camber and rubber bands?
Yes, they were made specifically for a lexus. I just don't know how far they will stick out with the spacers. Btw I'm lowered on eibach springs.
NO don't do it, if you took the time to look through this forum you would have found the answer... Btw all the guys above had LEGIT points and were trying to help you.
How far does the hubcentric stick out from the rotors (I've never measured it). It should be quite a bit smaller than 15mm so if that's the case you could use an H&R or similar spacer, I think they start at 5mm but not sure. It may be hit or miss though since not using the hubcentric may result in some vibration. I've heard it can occur sometimes
Another option to explore would be getting them machined to the Infiniti bore, not at all sure if it's even possible but might be worth looking into.
mmnjtwa
09-07-2015 02:27 PM
