Correct PSI on 20" Vossen CV3
Old 07-25-2013 | 01:11 PM
G Nepal's Avatar
G Nepal
I need help with the correct PSI on Vossen CV3s +32 - 245/35/20 NITTO 555 Front and +45 275/30/20 NITTO Rear. I am dropped on Eibach PK.
Any suggestions will be appreciated.
<I searched for the answer in the forum but no luck >
Old 07-25-2013 | 02:12 PM
The wheels and tires you have make little difference on the air pressure required for your tires. The recommended pressure is on a placard in the door jamb. You can increase it slightly if you like (1-2 PSI) for heavier loads or if your tires have a very soft sidewall.
DO NOT inflate tires to the maximum PSI on the sidewall of the tires.
Old 07-25-2013 | 03:10 PM
G Nepal's Avatar
G Nepal
I used to have 18" stokies. The door jam show 32 which I think is little low. I put 35 now but not sure if that's the right PSI.
Thank you for the input tho.
How you liking your M370?
Old 07-25-2013 | 03:17 PM
35 isn't too much.
I don't have it yet. But I probably won't install it anyway until my turbo parts arrive and install all the mods then.
Old 07-25-2013 | 03:24 PM
dkmesa350z's Avatar
dkmesa350z
haha these threads provide such good entertainment.
Old 07-25-2013 | 04:07 PM
G Nepal's Avatar
G Nepal
Talking
Glad I could make you laugh!
Old 07-25-2013 | 04:37 PM
dkmesa350z's Avatar
dkmesa350z
Can't you just inflate it to what the sidewall says anyway lol
Old 07-25-2013 | 04:40 PM
G Nepal's Avatar
G Nepal
LMAO... You DO NOT want to do that... That much I know.. lol..
Sidewall says .. 50psi
Old 07-25-2013 | 05:05 PM
When I had my TPMS sensors they seemed to turn the warning light on when I filled to 32 psi, never had any issues w/ them once I kept them at 35psi.
Old 07-25-2013 | 05:11 PM
G Nepal's Avatar
G Nepal
Great! 35 PSI it is then. Thank you all for the input
Old 07-26-2013 | 12:52 AM
BLAIR'N G372012's Avatar
BLAIR'N G372012
Nepal I have CV'5s 255/30/20's and run 35psi... though says 42psi to 50max I'm stretching so the shop that installed my set up did 35psi and not one issue ...
WARNED me if taking it to 40+ and hitting a pot hole or dip wrong I'd pop it... so 35psi it is...
G Nepal (07-26-2013)
Old 07-26-2013 | 12:02 PM
G Nepal's Avatar
G Nepal
35 isn't too much.
Turbo?!!! Yummy! lol
Dillybar12
11-01-2015 08:23 PM
stm37s
The M - Spot
14
10-23-2015 02:56 AM
stm37s
The M - Spot
10-01-2015 07:53 AM
John B
09-28-2015 12:41 AM
