Slip light comes on when I accelerate (2011 G37 Coupe)
Old 05-18-2013, 11:03 AM
TVPostSound
TVPostSound's Avatar
Originally Posted by NJ Torque
Check the brake fluid? Thats the first thing if it might be low...
THIS^^^^^
The tire diameters are fine.
Brake fluid is slightly low causing the float to set of the light.
Old 07-28-2013, 03:57 PM
monytx
monytx's Avatar
I think everyone got confused on this real quick..
Old 07-28-2013, 06:50 PM
BLAIR'N G372012
BLAIR'N G372012's Avatar
I agree... My 12 did the same thing as the OP... I had changed rims tire size yet went from springs to coils and even both setups did the same thing...
Even added sways shortly and made it worse on corners the traction light would come on all the time ... took it in for a alignment put in toe bolts and align and poof light was GONE... Haven't had it on once since then... tech said tires weren't firm on the ground yet toe was way off camber was fine... being a square set up you felt the difference ... back on Topic hope it helps in my case it did...
Btw traction control has nothing to do with brake... funny reading some of that.... its tire contact to the ground... chk air pressure too...
Op last note to hard of a tire will cause slippage ...but check your alignment
Clutch34
06-24-2022 10:48 AM
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
Ghost90
08-05-2015 11:19 AM
Quick Reply: Slip light comes on when I accelerate (2011 G37 Coupe)
