Vossen CV-5 10.5 +45
Old 05-07-2013, 09:54 AM
SkylineEX-S
SkylineEX-S's Avatar
OK Diego, I followed your advice and dropped the car a little bit more.
I filled up the car the other day and it looked like the car had an opposite rake. I measured and the rears were 25.5" to the top of the rear fender and the fronts were 26 1/8".
Bit the bullet and dropped the front to 25.5" It cambered the wheels in just that little bit more and it looks great imho. I'll run it for a week and see if I can live with the car that low.
Old 05-07-2013, 10:11 AM
Diego@Vossen
Diego@Vossen's Avatar
Love those tires bro! 265s look great. Good job.
Old 09-12-2013, 05:38 PM
KingstonSaints
KingstonSaints's Avatar
Unreal my friend. I'm brand new to the blog and just purchased CV5s. Should be here mid week next week. I have an 08 G37s Coupe in this exact color. The CV5s I got are 20x9 ET9 5x114.3 front and 20x10.5 ET45 5x114.3 back (Silver Polished as well)
What are you running as your set up buddy? for coils? How do I achieve this look? This is a dream look
Old 09-16-2013, 12:05 PM
SkylineEX-S
I'm running Tanabe Sustec Pro S-OC coilovers with a bit of negative camber front and rear. Ride height is 25.5" front and rear and I did trim off the rear bumper bracket and fender liner to make sure I have no issues with rubbing.
What tires will you be running?
Old 10-22-2013, 01:28 AM
Emillion45
Emillion45's Avatar
I wish someone could do this and at least TRY a 285/35 tire. I need to know if it will fit with the same wheel dimensions. I have been searching wheel setups for weeks!!
Old 10-22-2013, 09:59 AM
pebkac
pebkac's Avatar
Would this be the same route on a Sport Sedan for 10.5 all around?
Originally Posted by SkylineEX-S
To run 10.5 inch wheels in front you have to run a minimum +30 offset to clear the sport akebono brakes. Vossen does make 10.5 offsets in +45, +25 and +15.
I spent weeks looking at all the threads on the forum and all the pictures of different offsets and went with a +45 and 15mm spacers because I wanted to run something with less poke and more rubber than 255/30. I was actually on the verge of buying 275/30 rubber all around but I took the safe route and went 265. If I keep the car long enough for a new set of rubber I think I would go for 275's all around as I think at my height it would fit with no rubbing.
Going to go for a full alignment soon to see how far I can get it to spec.
Old 10-22-2013, 10:03 AM
Diego@Vossen
This would be a great route for your sedan as well. +45 with spacers will sit very nice.
Old 10-22-2013, 01:11 PM
SkylineEX-S
285's would fit on the rears with just a minor bracket trim. Fronts are already very very close with the 265's...
Old 10-24-2013, 02:42 AM
Emillion45
Emillion45's Avatar
I have coils so height wouldn't be a issue. The liner could be modified as well.
Having low pro tires on Ohio roads suck!
Dillybar12
11-01-2015 07:23 PM
stm37s
The M - Spot
14
10-23-2015 01:56 AM
stm37s
The M - Spot
10-01-2015 06:53 AM
John B
09-27-2015 11:41 PM
pal51961
09-27-2015 08:38 PM
Quick Reply: Vossen CV-5 10.5 +45
