Best tires to replace with for lease return
Old 04-05-2013, 06:39 PM
sirrach
sirrach's Avatar
So my lease is coming up soon on my g37s. I have to get new tires, so I was wondering what people typically bought when they were turning the car back in?
Old 04-05-2013, 06:41 PM
vivema
vivema's Avatar
Is there any fine print on the contract dictating this? If not, get some off brand tire, JinYu?
Old 04-05-2013, 06:46 PM
sirrach
sirrach's Avatar
I believe the contract states it needs the same speed rating, size, etc.
Old 04-05-2013, 07:04 PM
sniper27
sniper27's Avatar
I'm pretty sure you only need to have 4 matching tires. It can be any ratings. Just get the cheapest tires available.
akochman (09-09-2013)
Old 04-05-2013, 08:20 PM
mahonesbones
mahonesbones's Avatar
im in the same boat but i have a x so my tires are 17s-i called infiniti back when i saw the originals going and they said it can be any brand but has to be 4 matching tires and same size as the original thats it-i bought 4 nexen all seasons that actually has a higher speed rating and got them for 350 bucks shipped from tirebuyer-oh yeah the tread has to be 3/10 for the lease return
Old 04-05-2013, 08:24 PM
Received 4,943 Likes on 4,176 Posts
If you're going to lease another Infiniti they might work with you on the tire charge.
Old 04-05-2013, 09:16 PM
FourT2
FourT2's Avatar
When you are getting into another lease or purchase after a lease, sometimes the dealer can offer to just buy out the car from Infiniti on your behalf, and then doing a trade in, instead of you turning your leased car in to Infiniti. In this case things like miles, tires etc will not matter as much.
Old 04-05-2013, 10:08 PM
amt120
amt120's Avatar
Why get brand new tires. You can get those off brand tires used.
Old 04-06-2013, 11:02 AM
sirrach
sirrach's Avatar
I'd love to get another infiniti but no more 6mt. I'll look at the offbrand, and see what I can get. Any recommendations for purchasing? I usually use tirerack but not sure if there is anything cheaper. Also, do I need to get new TPMS or can I reuse the ones on my tires now?
Old 04-06-2013, 02:21 PM
You can go to some cut rate place like Cheap Tires Online, Discount Prices from tires-easy.com and as long as the size & speed rating match your OEMs you'll be fine. There are some really cheap tires out there, you'll probably be amazed.
Old 04-06-2013, 06:34 PM
JaxG
JaxG's Avatar
has to be the same size and speed rating. The last one I turned it were all brand new patched tires I got for a steal from a tire company I do biz with. They buy them from the dealers and patch them because the dealers cant put patched tires on new cars.
Old 04-06-2013, 07:06 PM
JohnsVert
JohnsVert's Avatar
Local tire shops usually sell used tires for cheap , I would look into that before buying new tires
Old 04-07-2013, 10:40 AM
sirrach
sirrach's Avatar
thanks guys for the suggestions, I'll have to check out some local tire dealers and ask them.
Old 04-07-2013, 12:22 PM
Good luck, the toughest thing to find is that front tire size, not too common, and to find a used set w/ those different sizes might be a hard find.
Old 09-09-2013, 10:19 AM
TONY37X
TONY37X's Avatar
Where do dealers and lease inspectors typically check tire depth? Center of tire?
Last oil change they listed mine as 5/32 to 7/32 but they are no where near that towards the outsides even with constant rotation and only 27K miles.
Quick Reply: Best tires to replace with for lease return
