What should I do?
#33
i called infiniti dealership and they told me that because the car is an x and the wheels are not the same front and back this could make the TPMS light go on.
i think i might just have to buy 2 rear wheels that are 225/45/19 just like the front. i dont see any other way around it.
I have a 2012 AWD coupe with the sport package and I run 245/40/19s on all four rims, even though the front and rear rims are different sizes. Keep in mind, you are only talking 1/2 of an inch difference in width. Just verify the rim width range for your tires. The tire manufacturer specifications will indicate a rim width range. For example, the tires I am running have a rim width between 8" and 9.5". These tires allow me to use the two different rim sizes on all four wheels with the same size tire. My AWD light has never gone on.
#35
Different size tires don't cause the TPMS light to go on. The only thing that causes the TPMS light to go on is a low tire pressure reading. I think they may have thought you were talking about the AWD light on your dash - that would make more sense. As I stated earlier, the AWD light may go on if you are not running 4 wheels with the same diameter.
#36
I have a 2012 AWD coupe with the sport package and I run 245/40/19s on all four rims, even though the front and rear rims are different sizes. Just verify the rim width range for your tires. The manufacturer specifications will indicate a rim width range. For example, the tires I am running have a rim width between 8" and 9.5".
#37
#38
He never said if he uses summer tires or all seasons. I am looking at going with these just because they are affordable, have a 40k mile warranty and have a lip for rim protection:
Firestone Firehawk Wide Oval AS (W-Speed Rated)
#39
Yeah I know it should be just fine. But I've seen people on these boards run a 245/35 and a 275/30 and have their vdc/slip/awd lights come on only to solve the issue by sticking a 285/30 on the rear. Just seems that some cars might be more finicky than others.
#40
Firestone*Firehawk Wide Oval AS (W-Speed Rated)
#41
how about these...
4 New 245 40 19 Falken Azenis PT 722 40R R19 Tires | eBay
#42
spoke to a service guy from infiniti today and he told me nothing will happen to the car if the front tires will be 225/45/19 and the rear tires will be 240/40/19. he told me it wouldn't affect the ride.
