Help 20 inch black wheels on a 2013 G37 Coupe
Old 08-04-2015, 07:18 PM
Received 4,943 Likes on 4,176 Posts
Originally Posted by H03AssAss1n
No but I'm going to test fit once I get some time. Once I do I'll let you know how it goes I Was just seeing if anyone else has run that high of A offset With any problems
If it's close you can always run a spacer, if you ever plan on going w/ a big brake kit then you may have to reconsider some spacing then as well.
Old 08-04-2015, 09:33 PM
H03AssAss1n
H03AssAss1n's Avatar
Thanks for the advice I appreciate it. I'll report back with the fitment
Old 08-13-2015, 06:21 PM
H03AssAss1n
I wasn't able to clear I had to order 1 inch spacers
Old 08-13-2015, 06:26 PM
Now you're down to running a 10" +30, probably going to poke a fair amount but if you run stretched tires (like 255s) they should tuck just inside the fenders but
You couldn't get enough clearance w/ a spacer in the 17 to 20mm range?
Old 08-13-2015, 09:31 PM
H03AssAss1n
I bought a four pack of spacers they only had 1 inch. It definitely sticks out but not that much. When I drop I plan on rolling the fenders I'll post a pic. Tell me what you think
H03AssAss1n
Old 08-13-2015, 10:41 PM
Link didn't work. How much spacing do you have between the caliper face and the back of the wheel/spokes? You might be better off keeping the big spacers for the back and getting thinner spacers up front rather than going through fender mods. If you have 7mm or more space available I'd try to go down to 20mm or less if you have enough space in the front. Fender mods (with the exception of flat-rolling the front fender edge) often turn out looking poor to very poor, and it will make your car harder to sell when the time comes.
WhyUmadMFKR510
Northern California
20
10-13-2015 03:04 AM
james6980
10-09-2015 01:28 PM
joeposter
09-08-2015 04:36 PM
sharmelan
08-25-2015 03:41 PM
dAgent
08-19-2015 06:49 PM
Quick Reply: Help 20 inch black wheels on a 2013 G37 Coupe
