Help 20x9 offset help
20x9 offset help
g37 journey sedan.
20x9 square setup with 245/35 tires.
lowered on eibach.
what offset should i run all around for flush without the rub/modification?
lowered on eibach.
I've got 20x8.5 on the fronts w/ 245/35/20s w/ +40 offset (and have about 6mm to spare), so w/ your 12mm wider rim (6mm added to outside) I think +40 would set you just about right. My rears are completely different 295/30/20 on 20x10 +45 and these are dead flush. Not sure how much difference there is in the fender edges front compared to back, I don't think they're the exact same though. I know the fronts aren't rolled like the rears.
ck1109
10-15-2015 11:06 PM
Kojack
10-09-2015 05:53 PM
