The OFFICIAL "I have a wheel offset / tire fitment question!" thread
IracknBack (04-13-2016)
#1369
Because I see lot more square setups of wide 18 inch wheels, and only few staggered setups (not as wide as recommended).
#1372
Looks great. Perfect fitment, IMO.
What spacers, 20mm? I'm guessing you've got 245/40s on the front. I've got 235/45s (AWD - X). I started with 15mm and ended up with 20mm. With the 15mm, I had to drill-press a bit of the rotor-side pockets to avoid contact with the lugs. Ended up not having to have done that, oh well.
Sean
Sean
#1374
What can you tell me about replicas?
I was able to find a set:
Volk Racing TE37 replica
18x9 255/35/18 +25
18x10 285/35/18 +32
for 750 bucks.
The seller used them on 350z
I think it's a good deal, but don't know much about replicas
18x9 255/35/18 +25
18x10 285/35/18 +32
for 750 bucks.
#1375
Don't listen to anyone or do any research
Just buy them already
#1378
Did a research, turns out replica weights 8 pounds more (each) than real thing.
Now I'm looking at this set:
SSR type C
18x8.5 +41, 245/40/18 front tires
18x9.5 +41, 255/35/18 back tires
Will this setup work for G37 coupe? I'm looking to get best performance at race track or autocross.
Is tire size correct? I'm asking because it's coming off 350Z.
Will they clear BBK?
Also: how do I tell if they are real or replicas? Because the price is only $800, which is about the same as previous set I've seen (those were replicas).
SSR type C
