The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#106
Niche targa
I have made up my mind. This is the wheel i want. Now i need width/offset answers. 2009 G37 Journey sedan lowered on eibach prokit with spc front/rear kit with toe kit. I want 19's. My question is for the rear. The car is on sitting on 19" coupe wheels now with 245/40's. It damn near tucks the tire now. What width and offset rear should i run? 9.5 or 10" with a 275? I want no rubbing and i do not want to have to camber the tire for clearance. Will there be any difference in the concave of the wheel between these two sizes? The 19x9.5" offset is +35. The 19x10" is +25.
#107
Are you going to run the 8.5" fronts or do you want the 9.5s in front too? The 9.5s in front will require a narrower tire for the front non-rolled fender clearance. I'd go 8.5" +35 245/40/19 in front w/ those 275s ion back.
#111
Natalies Sedan has 10.5s all around on 255s
https://www.myg37.com/forums/picture...g37-sedan.html
#112
If you are comparing a 19x9.5 +35 and a 19x10 +25, the x10 is going to be more concave. It has a lower offset and a the wheel is wider. If you want to PM me I can get you exact fitment for your car.
#113
No, 245s on 8.5" front
#116
I have an 08 g37s coupe. I just purchased new rims. 19x9.5/40 rear and 19x8.5/35 front. I have 10m spacers on rear and 15mm front. I also plan a mild drop on Swift springs.
My questions are: will a 275/35 and 245/40 tire work well with this setup? Any issues with rubbing? How close to flush will it be?
Thanks!
Thanks!
#117
Thanks!
Thanks!
Dave123 (02-20-2014)
#119
#120
Just got my new tires and thought i would share to help everyone out with fitment.
Suspension: Dropped on Eibach Pro Kit
Wheels: Front=20x9 +25 w/255/35/20 Michelin Pilot super sport
Rear=20x10.5 +38 W/ 295/30/20 michelin Pilot super sport
no rubbing what so ever but looks like my struts/shocks are shot because my front left is lower then the right side and the rear right is lower then the rear left.
