The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#1021
how would work meisters S12P fit with 18x9.5 +22 on an 09 G37S Sedan with Akebonos? or what is the better offset with the work meisters (only looking at 2p)
#1024
The great thing about those 2pc sets is getting any offset you want.
Look forward to seeing this come together.
These S1Rs in two tone bronze are sweetness!
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Work Meister S1R 18"
#1025
So I'm currently trying to decide on a set of tires to get for my new wheels. Most likely going to get the G-MAX AS-03 as they seem to have good reviews on Tirerack.
Would you guys think it's better to swap my TPMS over from my stock 17" wheels to my new ones or just buy a new set of TPMS sensors? How would these TPMS work?
#1026
Works can be tricky since they have the 3 disc depth choices, it's best to contact evasive motorsports or Rav spec and see which configuration is best. You typically want the most aggressive disc you can use w/ just a few mm caliper clearance so you get more of a deep dish look. The 9.5" is a good choice for a square setup, but if you want to run in-spec camber and not too much of a stretch w/ the tire I'd look at offsets closer to the +30 range. If you plan on running camber &/stretch then the +22 can work.
#1028
Would you guys think it's better to swap my TPMS over from my stock 17" wheels to my new ones or just buy a new set of TPMS sensors? How would these TPMS work? Amazon.com: VDO SE10003 REDI-Sensor 315 MHz TPMS Sensor: Automotive
#1030
If you still have your OEM wheels they should be 7.5 +45 Front 8.5 +50 Rear
So those new wheels would be 33mm further out in front and 38mm further out in back.
#1031
wheels
Just a quick fitment clarification question.
Looking at purchasing some wheels with the following specs:
19x9.5 +22 FRONT
19.10.5 +22 REAR
I have a 08 Coupe Sport package which means BBK. Now my plan was to run 245s and 275s in the rear but wasn't sure how it would fit with those offsets. Looking to avoid any rubbing. Any help is appreciated!
there also options with +12 Offsets but those are out of stock.
19x9.5 +22 FRONT
19.10.5 +22 REAR
#1032
19x9.5 +22 FRONT
19.10.5 +22 REAR
19x9.5 +22 FRONT
19.10.5 +22 REAR
https://www.myg37.com/forums/wheels-...-5-22-how.html
Yashpatel21 (01-10-2016)
#1033
How would I find out if a +22 would clear my brakes? I had a guy tell me it would be better for me to get +12 which as you told me BLNewt would stick out about 10mm from the fender. I think I want to go with the +22 because I plan to drop it. I'd put spacers on if I need to. How do I know? Why is wheel choosing so damn hard! LoL
#1035
And if you have a Big brake kit that just adds another hurdle to clear literally.
Like Jumpman said, sending these templates to the seller will help (if they're decent enough to take the time to do that).
https://conceptzperformance.com/imag...nttemplate.pdf
https://conceptzperformance.com/imag...artemplate.pdf
