The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old 08-11-2015, 06:45 PM
  #841
Received 4,943 Likes on 4,176 Posts
Originally Posted by pledes23
Hello,
I have a 2012 g37S Sedan and recently had to remove my Ace Mesh-7 wheels 20x8.5/10. Upon removing them the shop damaged the hub centric rings and they are unable to determine what size I need for when I put the wheels back on.
Wheels were purchased from original owner with the car and I am unsure of offsets.
Could anyone please guide me in the right direction so I could order the correct size needed? I am sending the wheels off to be refinished and will need the rings prior to.
Thanks in advance!
Here's the one's you'd need, but if you can find aluminum ones that would be better if you do a lot of wheel removals.
http://www.ebay.com/itm/like/140928995091?lpid=82&chn=ps
Old 08-11-2015, 10:08 PM
  #842
pledes23
pledes23's Avatar
Thank you Brad!!! As always you are a knowledgeable guardian sent down to us by the Infiniti Gods to help us!!
Old 08-11-2015, 10:44 PM
  #843
AroundTheG37
AroundTheG37's Avatar
Call up discount direct auto and tell them the size you need. They have them in aluminum and in my opinion they are a hundred times better than the plastic ones.
Old 08-12-2015, 10:26 AM
  #844
Monaco
Monaco's Avatar
One more basic question:
I'm looking at getting a set of the 19-inch OEM sport wheels from the G37 coupe. Is there anything I need to do/know or are they pretty much a direct fit? Also, what size tires are most AWD sedan owners running on those wheels? I was thinking 245/45 all around. Yay? Nay?
Old 08-12-2015, 02:02 PM
  #845
They're staggered but it's only a 1/2" stagger so running 245/40/19s all around is what you want.
Old 08-12-2015, 03:16 PM
  #846
Monaco
Monaco's Avatar
Would there be any reason to run 225's up front?
Old 08-12-2015, 06:43 PM
  #847
A little quicker turn-in but having AWD I'd stick w/ those 245s all round.
Old 08-22-2015, 07:18 PM
  #848
propho
propho's Avatar
I'm praying I can migrate my wheels from my G35 that was recently totaled..
I don't know the offset of the front but they are 20x8.5 /w 255/30's the rears are 20x10.5 +29 /w 285/30's..
Could someone give me some input on if I'm already doomed or is this doable?
Old 08-22-2015, 07:50 PM
  #849
Welcome to the site, sorry to hear about that G35 (hope no one was hurt).
If you have a coupe those should be "workable" maybe a bit more camber, a sedan would require fender mods, at least in back.
If you have an AWD those tires are way off diameter-wise front to back.
Old 08-27-2015, 10:33 PM
  #850
G37XS13
G37XS13's Avatar
Can you please let me know if the following setup will fit and work with a G37X coupe?
18x9.5 +22 245/45r18
18x10.5 +35 275/40R18
Old 08-27-2015, 11:27 PM
  #851
Can't really get any better than that w/ a staggered setup, and should look great too
I assume you're dropped.
G37XS13 (08-28-2015)
Old 08-28-2015, 09:45 PM
  #852
propho
propho's Avatar
Any thoughts.. I am really not liking how they look.. I am still on stock suspension but pushing down on the suspension to try and get some tuck didn't really do much for me..
The rears are 20x10.5+29 /w 285/30's
https://goo.gl/photos/45jKwkE2NK9Lx6Se9
These were originally for my G35.. I spent a long time getting everything set and then some ****head rear ended me and totaled it.. NEVER got to put them on the car.. so depressed..
Old 08-29-2015, 03:03 AM
  #853
Is that a Sedan or Coupe that you have now? By the look of the poke I'm guessing a sedan. Looks like you're going to have to run a stretched tire and heavier camber to get it to look better but the rim edge will still be outside the fender.
Old 08-29-2015, 11:08 AM
  #854
propho
propho's Avatar
That's the sad part.. it's a RWD Coupe.. I'll revisit once it's lowered any change in your thought since it's a Coupe? I'm contemplating these: http://www.ilovebodykits.com/product...k_1_pair_.html
I spent ~$2500 on new barrels, powdercoating, and new tires.. so far in that I can't back out now..
Old 08-29-2015, 03:24 PM
  #855
That's the sad part.. it's a RWD Coupe.. I'll revisit once it's lowered any change in your thought since it's a Coupe? I'm contemplating these: Universal Fender Flare Kit 10mm Front & Back (1 pair)
Tommie,
If you don't mind running heavier camber you should be able to get those to tuck in with enough drop. There is plenty of guys in the hellaflush thread that are running setups more aggressive and making them work. Might check that thread and post your setup, one of those guys should be able to help.
G/L
https://www.myg37.com/forums/wheels-...hread-103.html
Quick Reply: The OFFICIAL "I have a wheel offset / tire fitment question!" thread
