The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old 07-09-2015, 02:05 PM
  #796
Received 4,943 Likes on 4,176 Posts
Originally Posted by PacoL250
Hi all!
Going to join the G37 family soon; just waiting on the right time on the various options I have in my area. Coming from a 2004 Mazda 3s, so AWD is a must at this point. So as my sig says, I'll be rolling around in a G37xS sooner rather than later!
I've done a decent amount of work on my Mazda 3, and I'm looking to replicate that on the G37xS. I'm looking at the following wheel options that look like they'll fit with a squared setup from the research I've done and what I've found:
  • RAYS Gram Lights 57XTREME:
    • Sunlight Silver
      • Size: 18x8.5, Offset: 42mm, Bolt: 5x114.3
    • Matte Graphite
      • Size: 18x7.5, Offset: 40mm, Bolt: 5x114.3
      • Size: 18x8.5, Offset: 33mm, Bolt: 5x114.3
      • Size: 19x8.5, Offset: 45mm, Bolt: 5x114.3
I'd rather stick with as close as stock as possible in terms of size & offset; however, I know that might not be the case for some options. Any opinions on what would be best fit from what I listed above? Also, I assume a 245/45-18 would work on the 18x8.5 wheels, 225/50-18 on the 18x7.5 wheels? What about the 19x8.5 wheels; would it be 245/45-19?
As for the Enkei Raijin wheels, I'll call them my backups. I sized them out on Tire Rack and was given the following:
  • Enkei Raijin Gunmetal (Tuning Series):
    • Size:18x8, Offset: 45mm, Bolt: 5x114, Tire: 225/50-18
I'd figure I'd run into little issues with those, but my main questions are on the RAYS Gram Lights above.
Oh and of course, to complicate things, I'm looking at KSport Kontrol Pro coilovers with a very mild drop; however, I wouldn't want to get into that until I know what size wheels I'll be getting.
Thanks for the help in advance!
I'll help w/ the fit later (short on time) but need to know if your planned XS is a coupe or sedan, the offsets will be different and if you go w/ the XS coupe it will have the big Akebono calipers to deal with.
Old 07-09-2015, 02:46 PM
  #797
PacoL250
PacoL250's Avatar
Sorry, I forgot to update my sig and mention it was a G37xS Sedan I'm looking at.
Old 07-09-2015, 05:14 PM
  #798
ChinkyChoy
ChinkyChoy's Avatar
My current set up is 19x9.5 +25 245/40 all around looking for more an aggressive set up because I m going air. I have a 08 G35x sedan looking for a big lip in the rear
Potential new set ups:
19x9.5+14 high disk
19x9.5+17 low disk
19x10+20 high disk
19x10+24 low disk
20x10+33 high disk
20x10+24 low disk
20x10+20 high disk
20x10+11 low disk
20x10+20 high disk
20x10+24 low disk
Thanks!
Old 07-09-2015, 08:58 PM
  #799
Hi all!
    • Sunlight Silver
    • Matte Graphite
With a mild drop I'd run 19s, and the 19x8.5 +45 on 245/40/19s will be a good fit although I'd run a +35 offset if they have it available, it will look better being closer to the fender and you won't be so far out that you'll have any rubbing/poke issues. You could run up to a 9.5 +45 all around on the same 245s for a slight stretch but a bit more concavity in the rims.
PacoL250 (07-12-2015)
Old 07-10-2015, 04:47 PM
  #800
PacoL250
PacoL250's Avatar
Any thoughts on 18" wheels? I would rather stay at 18" for the sake of fuel efficiency (whatever I can get with this beast of an engine ), better ride, handling, etc.
When I mean mild drop, I mean no more than an inch. I was thinking around .75" drop up front and .5" in the rear. Maybe 1" in the front and .75" in the rear...just want to make sure I'm not "plowing snow" when it's that time of year.
Old 07-10-2015, 11:05 PM
  #801
No problem at all running 18s they're lighter, more comfortable, and cheaper.
Of the ones you listed the 8.5 +33 will give a nice fit at the fender, and again you could run a wider rim (up to a 9.5 +45) w/ those 245/45/18s.
For a mild drop Tanabe would be the mildest.
There's a lot of nice 18s on this site if you haven't seen some of them
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Wheels
Old 07-12-2015, 09:53 PM
  #802
PacoL250
PacoL250's Avatar
Question
You have been an awesome help!
So with a +33 offset (or any non-OEM offset), I'd have to get a hub centric ring correct? Any suggestions on a brand/type?
Old 07-12-2015, 11:05 PM
  #803
It's not the offset that makes a hub ring required but most aftermarket rims have large hub bores so they can sell wheels for a lot of vehicle models, you then should get the hubcentric rings so they center on the Infiniti hub to further reduce the chance of high speed vibration.
They have aluminum adapter rings on ebay, just need to be sure of the diameter of your new wheels' rings and then adapt down to the Infiniti diameter of 66.1mm. Tirerack sells plastic ones that are OK but don't hold up well if you're doing a lot of wheel removals.
PacoL250 (07-14-2015)
Old 07-14-2015, 08:46 AM
  #804
PacoL250
PacoL250's Avatar
Question
Silly question, but would spacers like the link below be the same thing as hub rings, or am I confused?
CNC Aluminum Bolt-On Wheel Spacers (20mm, 25mm, & 30mm)
Thanks!
Old 07-14-2015, 08:53 AM
  #805
Thanks!
Those are hubcentric spacers, these will push your wheel further out so your tires will be more flush to the fender or if you need more clearance for large brake calipers.
The hubcentric ring adapters are just these
Old 07-14-2015, 11:14 AM
  #806
micafd3s
micafd3s's Avatar
is anyone runnin a 19x10 with offset of 25 on all four.. checkin for clearance on a sport coupe lowered on eibachs..
calc shows that it will be protruding by about half an inch..
Old 07-14-2015, 07:04 PM
  #807
Here's 10.5 +25 on 275s so just 6mm in from this fitment
https://www.myg37.com/forums/brakes-...ml#post3891573
Old 07-21-2015, 12:08 AM
  #808
dtangdynasty
dtangdynasty's Avatar
I have a 2011 g37s sedan, stock suspension. I'm planning to run 245/40/19x8.5 front and 275/35/19x9.0 rear. Do I need spacers or will I be ok without?
Thanks in advance
Old 07-21-2015, 08:50 AM
  #809
Thanks in advance
That's a pretty common setup, the 275s are a bit wide for a 9" rim so you'll get more sidewall roll on hard cornering. As far as spacers, I'd get them mounted up then see if you want any spacing, real easy to add later on.
Old 07-21-2015, 09:46 AM
  #810
dtangdynasty
Thanks. I was also concerned about the front hitting the inside of the (I think control arm). I wasn't sure if spacers would be needed. I didn't know if people put the spacers to avoid the control arm piece or just to have it more flushed.
Quick Reply: The OFFICIAL "I have a wheel offset / tire fitment question!" thread
