The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#648
https://www.myg37.com/forums/brakes-...post-here.html
#649
I know nothing about Wheel offsets/brake calipers.
I find it interesting that at least in one place the offset is said to be 43mm.
What I want. I want to keep stock but improve it of I can.
So that means I want an 18" wheel.
But would a 30mm be a better offset? Will that bring the tire out a bit? How do I know if a wheel will clear the calipers?
I found an STR that I like but it is a 30 and the seller says it is not recommended for the G....
18x8.5 STR601B WHEELS 5X114.3 +30 BLACK RIMS FITS TOYTOA CAMRY SUBARU STI
I know this info is likely available here somewhere,but do you know how many posts there are........LOL....this forum has been successfully around for years....it is overwhelming
And most people want to drop the car and use big wheels.....I don't.....
And BTW I don't see a calculator at the top pf the page.......
Appreciate any guidance you can give.
#650
Hey guys,
im running 245/40/19 on 19x8.5 for the fronts and 255/40/19 on 19x9.5 for the rears.
in the rears it is rubbing like crazy and i need to change it asap! i was wondering if anyone know a good tire fitment for them? please help
P.s i am on tein s tech springs
#651
I found an STR that I like but it is a 30 and the buyer says it is not recommended for the G....
South3rn (03-24-2015)
#652
Hey guys,
Do you know your wheel offsets?
#653
Since you're dropped on S Techs you're probably rubbing on the rear bumper bracket, most guys just trim back the bracket w/ a dremel tool. I think I'd look into that first. If your offset is crazy aggressive then you might have to go a different route but check that first.
#654
Hi all,
I have a 2010 g37S sedan, eibach pro-kit springs being installed in a week, and will be ordering a new set of wheels at the same time.
I was looking into 18x9.5 +38 fronts 18x10 +38 rear. Tires will be 265/40/18 fronts, 275/40/18 rear.
Will this work? The only ones i've seen on the forums with 18's are narrower setups. Thanks in advance!
JT
JT
#655
Hi all,
JT
JT
desertrider1 (03-25-2015)
#656
Thanks BLNEWT!
I don't mind rolling the fronts a bit, just worried the rears might not fit. I won't be running a camber kit, so the extra camber from the pro-kit will help, right? (camber kit will follow in 2-3 months...still saving up)
JT
JT
#657
You'll be OK in back, your camber is probably running a bit over -2 right now so those 275s should just sneak in there.
#658
Gotcha! I'm trying to get as much rubber as I can in the front, as I find the car likes to push a little bit. I was going the squared route, but if I can fit a 275 in the back, that's what I'm getting. Thanks again for all your input. so hard to find the info I need for the sedans.
I'll post up a pic once I get everything installed and aligned.
JT
JT
#659
Does any one have 265's in the front on the g? Also Any idea if I will need any modifications to run such size in front? Some time ago i search about square setups and as good as they are, they put a lot of pressure on some suspension components, wanted to know if any of you guys have been running wide tires and what your experience is doing so.
#660
Just found a wicked deal on vossen cv3s for $900 (maybe even less), I am looking to put them on my 2011 g37s coupe. What are the chances of 20x10+20 will fit all around without being too stretched? I am not too keen on a square set up but if it works, at this price im willing to live with it.
