The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#511
Luff m1
Hey guys, I have another wheel fitment question for ya.
I have a 2012 g37s in moonlight white.
I am getting a smokin deal on some luff m1s. $400
They are 20 x 8.5 35mm front
20 x 10.5 42mm rear
Also, the guy is throwin in some 15 mm spacers.
So question is will they fit, how will they fit, and do I need to use the spacers to clear bbk?
Gonna powder coat black, and the lip color match moonlight white, will be sweet.
Thanks a ton guys. Car is coming together nicely, done r2s intakes, blackout grille, emblems, white front emblem, black rear valence, smoked tails, Cusco bar all in about a month. Next I need put on my hid fogs with day time halos. Pics soon.
Thanks
20 x 10.5 42mm rear
Thanks
#512
Do you have a coupe or sedan?
Only pics I've seen of these wheels were on German makes so need to verify that they're 5x114.4 bolt pattern.
Should fit OK on a sedan w/ a stretched tire mount, coupe may need small spacers to flush up in back and bigger ones up front.
Need to verify if they'll clear your big Akebono brakes. Here's a front template you can send to the seller to verify fit.
http://infinitig37.com/tech-images/akebonotemplate.pdf
#514
Luff m1
Sorry forgot to say I'm in a coupe. Also bolt is 5x114 so we good there. It comes with 15mm spacers as well, so sounds like will be decently flush in rear and semi close in front huh? I don't have to have hella flush like some, just close is fine for me. I can't beat the price either. $400 is cheap. When new they were like $1100-1400 I think. They are barely used too. Just too bad luff is outta business I think. So hard to replace if dent one.
Will prolly drop on eibach pros soon too. How do u think the gap will be on stock? Also, do u think I will need to invest in camber kit w toe bolts etc. I know it will save me some tire wear, but wondering how necessary it is for this setup?
But will do until I can afford my work vs-xx I really want.
Thanks again
Thanks again
Baby Jumpman (01-29-2015)
#516
Thanks again
Thanks again
I'd run 235/35/20 F 275/30/20 R or 245/35/20 F 285/30/20 rear. Those 15mm spacers will come in handy in front I'm thinking.
And don't forget to verify brake clearance.
#519
Don't have the necessary funds to buy new and the tire shop in town has a 255/40 set available.would that be ok and can i go 255/40 in the front? or should go around and keep looking? i know last time i tried this tire thing my speedometer ended up not working and dash lights turned on all over the place so i want to get this right. Thanks
#520
Another option would be to run 235/40/19 fronts if they have those on sale too, the 235/275 set is only 0.67% off
#521
Hey guys I'm looking to but some wheels I want 20x11 all around Idk what offset or tires would work please help I'm lowered on elibach strings almost a 2" drop I drive a 2010 g37x
#522
I have a 2012 G37x sedan. I'm using my stock 17's with snows. So I'm looking to get some summer wheels. Someone is selling the M45 Sport 19's locally. I know the bolt pattern will work but will I need to run spacers?
The tires currently installed on the M45 rims are 245/40/19.
Thanks
Thanks
#523
Thanks
Thanks
19" M45 Wheels Okay on G37X? : G35 and G37 Suspension, Brakes, Wheels and Tires
You'll probably want 15mm spacers to get the offset at +35 while running the 245s, should flush them up nicely. I'd get them first then decide exactly how much spacing you want though. Nice looking wheels for the G sedan IMO, classy but still w/ a sport look and a nice gunmetal shade.
#524
Here's a good thread on the topic~
#525
B2Autodesigns is a site vendor and their house brand hubcentric spacers get good reviews. Ask for Charles & mention the site for nice prices.
H&R and Ichiba also make bolt-on spacers that are decent.
http://www.b2autodesigns.com/index.p...8a8c3f83fc42c9
