The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#391
Bravo, you've done your homework
Both setups net similar fitments w/ the top set being about 3mm further in on the front, you might consider 255s in the front if you go w/ that setup since the 9.5" will be a bit stretched w/ 245s. Have you verified Big caliper clearance w/ the Rennens? Always nice to have your new setup that clears a BBK, as you may want to get the big Akebonos down the road.
Other than that you should be good to go, those gramlites are a pretty hot looking rim IMO.
If you don't mind rolling your rear fender edge you could get 285s back there too
Bravo at (09-17-2014)
#392
Recommendations accepted. Thanks Blnewt!! Edited my original to update tire sizes. Still open to ideas, opinions, recommendations.
#394
The rear on the '08 Coupe does have a flat edge on the fender. What do you think of the Rennen CSL-2 sizing/configuration. Appreciate the help. The set-up I described above is going for $1375.
#395
And again, those Rennens have a pretty good lip and those aren't always able to clear the big calipers, that would be my main concern w/ that set. This template is useful if the vendor can't verify clearance
http://infinitig37.com/tech-images/akebonotemplate.pdf
#396
Need some advice on fitment and tire sizes. I recently bought a set of used Stance ST-1's
20X8.5 +35
20X10 +38
With my research, these should not rub, is that correct? What would I need to do to make these flush?
The front two came with new tires but the rear's are bald. I was considering 275/40/20 or 285/35/20. I'm at stock height and don't plan to lower until next spring. Which tire would look the best, I'm looking for meaty tires.
20X8.5 +35
20X10 +38
#397
20X8.5 +35
20X10 +38
20X8.5 +35
20X10 +38
#399
The 275/40s are way too tall, by almost 2" for a whopping 6.7% taller than OEM, for RWD 3% is considered the most variance you should shoot for.
The 285/35s are better but still almost 4% taller.
That's the tradeoff for going w/ larger diameter wheels, the tires sidewalls have to shorten to make up for it.
FWIW a 275/35/20 is right at 3% so about the "meatiest" tire I could recommend.
BTW, what front tire size are you running?
#403
