The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#1547
Originally Posted by Project-vipg
Been researching seen 20x10.5 et 38 or so is pretty common but I am bagged so when I air out I gain a lot of camber wondering if anyone has done 20x10.5 +10 square on a sedan looking for lip to fender fitment
#1548
That's easy Mike, those will tuck just fine under compression. The look right now is a bit poked but nothing crazy. A milder Eibach or Swift drop will have you looking proper, and even as it sits (with the exception of the tire/fender gap) it's not bad at all.
IIRC the tires will tuck about 1/3" for every 1" drop, so a 1.25" drop will get you just about the 10mm you're extending from the fenders.
Thanks for calming my nerves, blnewt! After some more research last night, I'm going to get some springs on order. Swift and Eibach do seem to be the best for what I'm looking for. Wondering if I need to order front and rear camber adjustments now or if I should install springs and get an alignment first. Seems like there is mixed feedback on if the camber kits are needed or not.
#1549
The front is up to you, w/a mild drop you can usually get reasonable front tire wear since the toe is fully adjustable up front.
FWIW here's a G sedan on 9.5 +35 on 245s on a swift drop, the wheels are 6mm further out than you, but the tires are 5mm in, so essentially a similar fit at the uppermost fender edge (your actual wheels will be 6mm in from his) so in short, a great fit!
https://www.myg37.com/forums/g37-sed...ml#post4052355
#1550
That's what I thought as well, but I didn't realize how much camber I gain although it would be less gained with 2" bigger wheels mabey some thing more modest like 22-28 offset and I don't know him but I'm pretty sure I know what g you're talking about?
#1551
Was wondering, currently have 18" oem rims that are battered due to the person I bought the car from (09 g37x coupe), would 19" black rims from a journey coupe fit with no problem? Also, what tire size would some of you recommend for the 19"?
#1552
They should fit but since you have AWD you want to keep the tire sizes as close to each other as possible. 245/40/19 should fit all around, even though the wheels are staggered (only slightly; by half an inch). I ran this exact on my AWD sedan and it was fine.
#1554
You will in the back, if you have a dremel tool you can do the toe slot yourself and save some $$.
I decided to order some swifts and an SPC rear camber kit. Everything arrived yesterday and after a full day in the garage today the springs and new wheels have been installed. I'm super happy so far. Swift springs appear like the perfect DD drop. I wouldn't want anything more. I need to take it easy for a few days and then get an alignment. The wheels are almost perfectly flush with the fenders. Maybe just a mm or two of poke in the rear. That might change after alignment.
Thanks again to blnewt for the advice and for "convincing" me to go forward with a mild drop.
Konig Oversteers in Opal (19x8.5 +30) and 255/40/19 Cooper Zeon rs3-as all around...
nisslover (08-10-2016)
#1555
Awesome days work Mike, looking great, and those Konigs are a pretty lightweight wheel so you shouldn't notice too much lag from going bigger.
Probably about 5 days of minimal driving should get you settled enough for aligning, and probably get you another 1/4" drop in the process.
Solid job there!
Solid job there!
#1557
Originally Posted by celwin
Just want to be 100% certain. will these clear Akebono? They are both OEM wheels.
#1559
The duck feet ones are all 18x7.5. They are off a XS without the Akebonos. Hence the reason Im not sure since they are not staggered.
