The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#1531
Haha thanks blnewt, just trying to learn something. It's always harder to figure out a setup when you can't physically test it yourself on the car. I was hoping to get the 245/285 setup because if the rolling variance is so miniscule. Plus, if I'm buying new wheels, might as well take this opportunity to upgrade my tires sizes, too.
#1533
Hey, when measuring the variance...how do you properly calculate the numbers between front and back seeing as they are different sizes? Do you take whatever number for both and divide by 2 to get the average? Just curious of the best way to do it...the most accurate
#1535
Plug in the front tire on top and the rear tire on the bottom. If you have a negative % the tire on the bottom is smaller, if the % is positive the top tire is smaller diameter.
Ideally you want a slightly larger diameter in back since the rears wear faster, this will bring the variance closer to zero over time. If you start w/ a smaller diameter in back the variance will get worse over time.
And once you get tires w/ a good variance you can go to the tire brands' website and look up the exact diameter for that tire model & size, then just divide one diameter by the other to get the true variance of that brand tire at those sizes.
FWIW here's a list of some of the more common sizes in combos that will work w/ AWD staggered setups~
18s
235/45 & 265/40 (0.07%)
245/45 & 275/40 -0.07%
255/45 & 285/40 -0.22%
19s
235/40 & 265/35 -0.37%
235/40 & 275/35 0.67%
245/40 & 275/35 -0.52%
245/40 & 28535 0.51%
20s
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
the93owner (06-26-2016)
#1536
This method wont work for a square setups. Well i'll have to right down the differences and then do the math.
So for mine the fronts end up .06" (.22%) and the rear is .31" (1.17%)
So if I divide the rear by the front it ends up being 5.32%. Is that right? That seems awfully high and problematic apparently.
#1537
What tire size are you wanting to run?
#1538
I'm also confused. If you run a square setup, that means front & rear tire size will be the same so there's zero difference.
#1539
^^^Exactly. I will be running 255/40 19 square. If I do the math according to the calculator, both wheels, compared to stock size, are close as you see from my previous post. But when you do the average as you said the overall % difference is like 5%. That seems high.
#1540
evil-G-nius (06-26-2016)
#1542
I assume w/ your bagged setup that you want to run a pretty aggressive set.
I'd post over in the hellaflush thread just to get some guidelines.
https://www.myg37.com/forums/wheels-...sh-thread.html
For a lowered G (on coilovers) to zero gap running 8.5 front you could go w/ a +20 offset on 245/40 and 10.5 +35 on 295/35 in back.
#1543
Help!
Help! I have a 2013 G37x Sedan. After reading up on wheels for quite awhile and after talking with Discount Tire I purchased a set of Konig Oversteers in 19x8.5 +30 square with 255/40/19. I liked the meatier/wide tire for a little extra curb protection. Unfortunately at stock height I have almost 10mm of poke outside the fenders. My question is #1, can this size/setup work on sedans (under compression will this hit my fenders) and #2 could it be fixed if I dropped it about an inch or run some negative camber? How much would a mild drop effect the poke i have? What are my other options for making these wheels work ie. springs, camber adjustment, etc? Thanks in advance. blnewt take the wheel!
#1544
That's easy Mike, those will tuck just fine under compression. The look right now is a bit poked but nothing crazy. A milder Eibach or Swift drop will have you looking proper, and even as it sits (with the exception of the tire/fender gap) it's not bad at all.
IIRC the tires will tuck about 1/3" for every 1" drop, so a 1.25" drop will get you just about the 10mm you're extending from the fenders.
#1545
Been researching seen 20x10.5 et 38 or so is pretty common but I am bagged so when I air out I gain a lot of camber wondering if anyone has done 20x10.5 +10 square on a sedan looking for lip to fender fitment
