Help Can a 19x12 work in the Rear for g37S
Old 02-22-2013 | 01:01 PM
SoulSeeker's Avatar
SoulSeeker
Smile Can a 19x12 work in the Rear for g37S
I am thinking of running a 19x12 in the rear with a +34 offset. The Question is will the inner clearance fit. What i am worried about i see some guys running a 10.5 +45 offset wheel which works but i would have 8mm less of inner clearance with my wheel width and offset. Will i run into any issues of rubbing in the inside towards the suspension or am i good to go.
I used this website to determine the offsets and specs.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 02-22-2013 | 01:27 PM
cardoza's Avatar
cardoza
Someone correct me if I'm wrong, but that sounds like uncharted territory. I'll do some more looking around but I think the best bet you'll have is finding someone running an 11" et45 or so for comparison.
Also, I know you didn't ask this, but I think you're going to have a lot of issues fitting a 12" wheel without going widebody.
Old 02-22-2013 | 09:04 PM
TheGanglyGoon's Avatar
TheGanglyGoon
Ya man you can run that. There is a guy on here running 19x12 his name is Jorge
Old 02-22-2013 | 10:34 PM
LegitMW's Avatar
LegitMW
I ran a 11+15 with no issues if that helps.
Old 02-24-2013 | 02:53 AM
SoulSeeker's Avatar
SoulSeeker
Thanks for the heads up
Old 02-25-2013 | 01:02 AM
red g37s's Avatar
red g37s
Jorge is wide body
Old 02-25-2013 | 02:09 AM
TheGanglyGoon
Originally Posted by red g37s
Jorge is wide body
he wasn't always widebody though... he went widebody after his accident.
Old 02-25-2013 | 04:32 PM
Italia311's Avatar
Italia311
widebody G37?? must see this.
Old 02-27-2013 | 12:02 AM
GET_SOME's Avatar
GET_SOME
19x12 in the rear is what jeorge is running and he was rubbing his suspension pretty bad. his offset was 20 which means your 34 offset will not work period.
Chris Olson
03-28-2024 10:46 AM
GW330
02-02-2024 06:41 PM
GXXXVII
General Tech Questions
12-11-2021 09:58 AM
warpeacelove
10-28-2015 03:59 AM
Rogue_G
09-17-2015 10:44 PM
