BBS wheels
BBS wheels
I found a deal on some BBS wheels and the bolt pattern is 5-112 i think my AWD is factory is 5-114 will the 5-112 work for me they are 18x8.5
If its a really good deal maybe you can get correct lug pattern drilled for them. I personally wouldn't recommend it since it would put a lot of strain on parts that could be dangerous/fatal if they fail.
they said i shouldn't do it.... but i am looking for some CH 013 BBS 18x8 bolt pattern 5-114 if anyone comes across some please PM me. and would it a bad idea just to go 18''s being that my sport came with 18''s?? i am hearing the ride is rough with 20'' and 19 tires are just as expensive, plus i would be able to leave this on all year round.
BBS forged alloys are excellent wheels. I might suggest the RG-R model for the G as they come in the right bolt pattern and center bore. Meanwhile, the 18" size is actually better for performance, as the lighter weight will aid acceleration, braking and fuel mileage.
year i checked the site... and they are 21 or 22 pounds per. i am not sure how heavy factories are.... and 5-114 is the right bolt pattern
![Frown](https://www.myg37.com/forums/images/smilies/frown.gif)
Yes, there's a big difference in the way each wheel is built. The RG-R is a true forged wheel and is lighter, stronger and more expensive. The CH uses a aluminum casting and BBS technology called "flow forming" to help mold the wheel rim. Cheaper, but the CH can't offer the reduction in unsprung weight the RG-R does. You get what you pay for.
