Work meister s1 fitment
I just purchased a set of 19x9.5 +24 r disk and 19x10.5 +23 o disk work meister s1 wheels. I've searched but doesn't seem like many run this wheel or offset. Either really aggressive or really conservative specs. My question is, what tire size and do I need camber arms? I'm dropped on bc coils and a sport model. Thanks in advance!
Those offsets are semi aggressive and will give a you a flush fitment. You'll probably want a camber kit for the rear so you have the option dial in the camber a bit. Depending on how low you plan to go, you may also need to trim/relocate your bumper bracket. As for tire size I'll let the guys running 19 setups chime in.
Thank you for the replies. I was looking to getting around the bumper bracket trimming but I guess it's inevitable. The r disk is similar to high pad for other brands. It's supposed to be for bbk in which I hope it clears the brakes. I really don't want to use spacers. I'll go with 235/35 & 265/30 tire sizing then. Anyone else can chime in if I'm totally going the wrong route? I'm lowering the car to where the tire are at the fenders for reference.
mmnjtwa
09-07-2015 02:27 PM
RAVSPEC
Wheel & Tires
10-29-2011 04:16 AM
