Oem Infiniti rims on a sedan
hey guys need some help been trying find oem infiniti rims for my g37x sedan but no luck, i spoke to dealer and they tell me that the biggest size they make for oem are 18' only the coupe makes 19' and 20' but they are staggered and they lug pattern is different from sedans... guys i have seen sedans with oem rims how do they do it? i have awd how can i put coupe rims on a sedan or where can i find these oem infiniti rims for a sedan? please help me out on this one i need rims and tires asap
hey thanks dj so i can put coupe rims on my sedan ? what is 10.5" ? i know my rims size suppose to be 5x114.3 all i know...sorry if this comes across like stupid question but im a newbie on all this ...wouldent that be considered staggered?
You can find the rims anywhere these days. On the street, on ebay, on craigslist, or even on this site. About 2 months ago I saw a set of 19" Anniversary Edition style wheels for sale on Craigslist with tires for $1100. They were repainted gunmetal grey, but that price it was a steal. I also saw a mint set of take-offs of the same wheel on ebay for $3000. You just have to search, and be patient. If money is no object, theres always the dealer but walk with lube. Believe it or not, a lot of coupe owners will take your stock wheels plus cash for theirs as they most likely are upgrading to a staggered set of 20's like Vossen or other quality wheels. In my opinion the Enkei wheels that came standard on the 07-08 G35S sedan (optional performance wheel & tire package on the 2010 and newer G37x sedans- awd only) look really nice. Either those or the 19" coupe wheels are a direct fit bolt on. NO MODS or spacers necessary, and you can go staggered if you wish. I personally wont do staggered on my XS, unless its a set of Vossens. Good luck with your ride.
ok please calrify this are the coupe wheels staggered like the factory 19" or 20' that come on coupes are those staggered trying stay away from staggered because my sedan is awd...
Like mentioned earlier, no need to worry about running a staggered setup on AWD as longs as ALL tires are within 3% of each other in outside diameter. The factory staggered tire sizes are all within this parameter so if you get staggered OEM wheels w/ the original sized set of tires you'll be OK. Just keep in mind that you can no longer rotate your tires like you could on a non-staggered setup.
ALL tires are within 3% of each other in outside diameter??? what does that mean please explain im not to savy with this... how would i determing what size tires does that eqaul?
so is ok to get a set rims from a coupe even tho they are staggered as long as the tires are factory? is that what you are saying please help guy i really need get this tires asap
Is not about research buddy lol i dont want **** up my car...is not about size that fit but more if staggered wheels can be used on awd cars...if i can get passed this then size i can find...
Here's a good tire calculator
Tire Size Calculator - tire & wheel plus sizing
Just enter the stock tire size and below enter other tire sizes you might be considering. If you have different tire size in front & rear enter one size on top & the other in the lower column, if the difference in outside diameter is less than 3% between the tires you've got a winner.
If you're going w/ Infiniti factory G wheels just use the stock tire sizes that came with them and you'll automatically be within the 3% range. If you start wanting different tire sizes then you'll need the calculator. Hope that makes sense
Dj and bl great help, appreciated im starting get hang things...so pretty much can go staggered or use coupe rims as long diameter size is not off by more 3% ok makes sense...so what im planing do is find some coupe rims that come stick tires that would mean tires are all same size...or i could jus buy rims w/ out tires and choose my own tires as long as i stay close diameter specs. Ok so now to find a good pair oem rims.
