fitment question
Coupe or Sedan?
How low are you?
If coupe then maybe, but require lots of work. e.g roll/pull fenders, camber kit, toe bolts, and you will have to run a lot of stretch on the tires. The front should clear the BBK but you should know what disk it is? e.g O disk, R disk.
If you are trying for a sedan again the fronts will fit fine with the right size tire, but hell no to the rears. I think it would be better to run the same size all around or go different widths on the staggered setup.
RAVSPEC has some GS2's that would work just fine on the coupe, but are semi aggressive for the sedan
How low are you?
![](/images/staff.gif)
20x11 +11 is a no go on the G37 unless you're aiming for such a look:
![](https://external.ak.fbcdn.net/safe_image.php?d=AQC5wUlJZGqXYiGs&url=http%3A%2F%2Fb.vimeocdn.com%2Fts%2F333%2F340%2F333340140_640.jpg)
mmnjtwa
09-07-2015 02:27 PM
