What tires are ya'll running on your OEM 18s??
I originally went with the A/S plus because I was looking for a sporty tire that was quiet and comfortable since I do a lot of HWY driving at the Eibach and Coupe 19s setup was draining on me.
So i put those tires on, and it like, turned the car into a marsh mellow. I wanted comfier and quieter but not like a wobbly wandering thing that squeeled in corners like a pissed off pig.
I think what Im realizing is that summer tires probably wont be too bad if i get some that are rated nearly at the top and its in an 18" wheel size with a beefier side wall. That will retain the nice compromise between a compliant ride that still feels sporty. Nam' sayin?
For shiggles, this is what my car used to look like.
![](https://sphotos-a.xx.fbcdn.net/hphotos-snc6/205280_3906783900437_279115608_n.jpg)
Continental ExtremeContact DW.
Quite a bit comfier and quieter than the Ventus V12 prior. The sidewalls are soft, but noticeably better than the V12. Ultimate grip is significantly higher than the V12s*. It performs excellently even in puddles.
It's a little odd, high speed sweeps will see the tread biting down. Quick maneuvers will be a bit soft initially but then the grip takes over and keeps holding. Keep going and a short while later it'll start being audible while still keeping traction. I haven't been able to break it loose yet.
Can't say much for traction when gunning from a stop though, i don't usually drive like that.
However, i'll say this, i haven't been able to get TCS lights on when spiritedly taking off while raining. The V12 didn't like that.
![Big Grin](https://www.myg37.com/forums/images/smilies/biggrin.gif)
Just wondering what tires you are all running on your stock 18s?? And does anyone have pics of what they look like?
I had Pilot Sport A/S Plus and they sucked so much that im returning them and getting some Super Sport Michelins. I hear a lot of people have them on their 19s, but nobody has them on their 18s yet.
Since I only have about 3,500 miles on it....still have the RE050's. Not too bad to me...just a bit noisy on concrete roads, and heavy...
Check out this link - C&D liked the Michelin PSS. I will be going in this direction when a replacement is due...or sooner...
Monsters of Grip: Nine Summer-Performance Tires Tested - Comparison Test - Car and Driver
cheers! Mike
I can add to this as well- I'm running PSS on OEM coupe wheels in OEM fitment and I've noticed no "squishy" sidewalls or delayed response. I have notice much more maximum grip, a little more road noise, and a hair less bump compliance (more likely attributable to the 19" upsize).
I'll buy them again when the time comes.
#30
Couldn't agree anymore. Also had sway bars installed with new PSS's on 225/50, 245/45. Less road noise, and a much smoother ride. it's a little shocking how well the car drives now.
